Oct-08-2019 11:38 AM
Oct-09-2019 09:59 AM
campermama wrote:GrandpaKip wrote:
Instead of messing with the pressure relief valve, why not just open a faucet on the hot side? It’ll do the same thing.
Something definitely screwy with the valve.
I did open faucets first, but when I released the pressure valve water still came out.
Oct-09-2019 08:22 AM
opnspaces wrote:
Did you check if your valves were only 1/4 turn valves? Or are they the ones that turn a few revolutions? If they are the screw type and you never touched the cold valve then it's still open and needs to be closed.
Oct-09-2019 08:18 AM
Oct-09-2019 06:55 AM
Oct-08-2019 07:08 PM
Oct-08-2019 06:44 PM
ScottG wrote:campermama wrote:wopachop wrote:
Might not want to open the pressure vent. Lots of plumbers over the years have told me to never touch them on residential water heaters.
??? not sure what you are talking about? I'm talking about my rv
Your RV WH has one too and many of us open them to speed up draining. It's a gamble though because sometimes they leak forever more after that.
So it was good advice that also goes for RV's.
Oct-08-2019 04:38 PM
Oct-08-2019 03:33 PM
Oct-08-2019 01:46 PM
Oct-08-2019 01:11 PM
Oct-08-2019 12:52 PM
Oct-08-2019 12:51 PM
Oct-08-2019 12:31 PM
Boon Docker wrote:
If the blue line valve was closed you would not have gotten any hot water at the faucet, so it must have been in the open position.
Normal RV operation:
Red line valve open
Bypass valve closed
Blue line valve open
Bypassed:
Red line valve closed
Bypass valve open
Blue line valve closed
Oct-08-2019 12:07 PM
