Every 30 minutes is a small leak....loss of system pressure
Could be:
Pump Internal check valve
WH Tank T&P Relief Valve weeping
WH Tank Drain Plug leaking
City Water Inlet Check Valve leaking
Fittings Hot/Cold on WH Tank, Sinks, Showers (inside/outside), Toilet
Fittings on Hot/Cold Water Lines at 'T' s
Low Point Drains Hot/Cold dripping
Wrap Toilet Paper around fittings/connections and then check later if damp
Inspect T&P, Drain Plug, City Inlet, low point drains for dripping
Using Pump can sometimes clear the check valve
***One reason I always use pump only ---short cycles w/o demand indicates a leak
