water tank
Dome
posting for a friend, he wants to know where the water tank is on his i-go lite trailer is? He thinks it's under the sink but there is no why to access it unless he take a panel out. Is this correct?
6 REPLIES 6
Old-Biscuit
Dome wrote:
he fills the tank through a port that is under the kitchen window. I was thinking the tank would be there but I don't that area has enough space for a 35/40 gallon tank. I'm thinking the tank is in the back half of the trailer there is a hot and cold water drain back there. I guessing there is no access to the tank sense it is between the frame rails. thanks for the information.
Access to tank then would be from underneath. If enclosed underbelly then have to remove section for access.
Standing in front of kitchen window....probably standing right over tank
Dome
he fills the tank through a port that is under the kitchen window. I was thinking the tank would be there but I don't think that area has enough space for a 35/40 gallon tank. I'm thinking the tank is in the back half of the trailer there is a hot and cold water drain back there. I guessing there is no access to the tank sense it is between the frame rails. thanks for the information.
Old-Biscuit
Under bed
Under sofa
Under bench seat
Under....where they can fit it.
Where does your friend fill his tank...it's opposite/below the fill port
HappyKayakers
In the absence of verifiable information, above the axle(s) would make sense since that's the tank most likely to be full when traveling and it would keep the extra weight neutral.
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Bigbird65
Look under the trailer for a drain spigot. The tank will be above it.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
robsouth
Look under the bed. That is a common place for fresh water tank.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
