Hi again Jim,
I would estimate your tongue weight to be around 1250lbs - possibly a bit more. Remember, that weight of the trailer you got at the scale included the weight from the tongue that was transferred back to the trailer axles by the WD hitch. You most likely have around 200-250lbs moved back there when you draw up the bars. I would say you have just the right sized WD bars.
Take a look at the first post in
this thread if you have not already done so.
To get accurate figures you should weigh your rig as follows.
1) front axle load and rear axle load for TV only.
2) front, rear, and combined TT axles for TV plus TT with no WD applied.
3) front, rear, and combined TT axles for TV plus TT with WD applied.
Doing this will let you figure all the numbers you need to get accurate WD from your hitch, loading information for your truck and trailer, and determine if you are within all ratings. This may not be possible at the DOT scales but is well worth the small amount of money paid at a Cat scale or similar.
Actually, to be 100% sure, you would need to measure the weights under each wheel but most of us do not have that opportunity.
Barney
Not towing now.
