Weight Bunkhouse trailers
mjc1123
We have narrowed down search for travel trailer to a few different models ranging from 5000-6000 pounds.
I am newbie to RVing and towing so I am naturally cautious of getting a trailer that is too big.
My tow vehicle is a 2005 Ford F-150 XLT, Styleside, 5.4 triton engine, supercab, 35,000 miles.
The towing capacity from ford is 8600 pounds and the payload is 1820. It would be three of us in truck (approx 400 pounds) and would be bringing normal camping supplies plus bicycles etc...
I have read many posts and articles from the forum and quite frankly I am a bit confused.
The hitch I plan to use is the Blue Ox Sway Pro.
I am just looking for some insight on above scenario and any other advice based on my TV and choice of trailer.
Thanks,
Mike
7 REPLIES 7
badercubed
With 1,800+ in payload, I see no reason that you wouldn't be completely fine with a trailer that size. Going to the scales wouldn't even be a thought in my mind.
2019 Apex Nano 208BHS
2016 F-150 Crew Cab (it's my wife's ride)
Been camping for 37 of my 38 years!
mjc1123
I think I will settle on a trailer that weighs 5000 dry. Don't want to push it. I have no experience so please keep replies coming. Especially, anyone with F150 and similar setup.
Thanks
LOWELL731
Mike
I tow a 2010 Jayco Jay flight 26bh with a 2004 dodge quad cab 1500 with a Hemi 345hp motor. I have never had any problem pulling or most important stopping it. I think I have a little less payload and towing capacity then your truck but within limits. Good luck with the search that alone is half the fun.
lowell
Tystevens
We have towed the bunkhouse in my sig many miles w/ 1/2 tons and it works just fine. We are about 6000-6500 lbs loaded to camp. Tongue weight is about 800 lbs. We use an Equalizer 4-way and it does the job.
Our trailer is very basic -- no slide, basic appliances and so on. Adding slides will get the weight up pretty quickly, unless it is an ultralite build. Which will get the price up pretty quickly.
2008 Hornet Hideout 27B
2010 Chevy Suburban 1500 LT, Z71 package, 5.3/6A/3.42
2015 Ford F150 XLT Supercrew, 2.7 Ecoboost/6A/3.55 LS
Prior TVs:
2011 Ford F150 Ecoboost 3.5
2006 Chevy Silverado 2500HD Duramax LBZ
2005 Chevy Suburban 1500 4x4 LT, 5.3/4A/4.10
AH64ID
Mike,
You will likely run out of payload and tires first. I suggest loading up the family and normal camping gear and finding a scale, with a full tank of fuel.
This will tell you where yo are at. Then add 75lbs to the rear axle for a WDH and determine how much weight you have left. Divide that number by .15 (IME BH trailers are higher on TW) and that's the most the trailer can weigh. Look for trailers that are about 1500lbs less than that dry and you will be fine.
-John
2018 Ram 3500-SRW-4x4-Laramie-CCLB-Aisin-Auto Level-5th Wheel Prep-Titan 55 gal tank-B&W RVK3600
2011 Outdoors RV Wind River 275SBS-some minor mods
mjc1123
Thanks, I appreciate the response.
Merrykalia
I don't know where all the weight police are this morning. I'm surprised some of them haven't hopped on here to tell you that you can only pull a small popup with that truck.
Anyway, with the towing capacity that you have, you should be able to pull a trailer in the range you have set. Be sure to check out your hitch capacity, because your WDH and sway will add another 100 or so pounds....those things are heavy.
You will also have to remain pretty vigilant to not keep filling up the TT. It's amazing how much stuff you accumulate in a year or so. When we dumped ours before selling, we put it in our storage building. We then purchased a fifth wheel, we only put about half of the stuff back in.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
