I throw some ballpark numbers around. Update them based on your specifics and you will get a fairly good approximation.
Let's say total current length is 25ft and the center of the axles is 15ft behind the hitch. The center of gravity of the bike and rack will sit 13ft behind the center of the axles. The rack will weigh 200lb.
Assuming the starting hitch weight is a healthy 15% and loaded for travel it weighs in at around 6500lb (assuming 4500 is the empty weight) results in a hitch weight of 975lb to start.
You are adding 500lb (bike and rack) should take about 433lb off the hitch leaving a hitch weight of 541lb which is around 7.7% hitch weight. That's way below the 12-15% recommended.
PS: This ignores the question if if the frame can even handle the weight. If it takes a lot of beefing up, it could easily result in the rack being 300-400lb. You also have to consider if the axles are spec'd to handle the load. In the original situation, if the weight = 6500lb with a 975lb hitch weight, the axles only have to carry 5525lb. If they put a pair 3000lb axles on that's fine. But with the bike on the back, the axles are now expected to carry 6658lb out of the now 7000lb loaded trailer. That would mean overloaded axles.
Assuming he is towing with a capable pickup, a better option would be to put the bike into the truck bed. Obviously, he would need an extra 300lb of payload but it would only require some straps/blocks to hold it in place and the trailer itself would never be compromised.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
