โApr-18-2014 07:25 AM
โApr-23-2014 10:35 PM
MM49 wrote:JJBIRISH wrote:Talk is cheap on the internet. Yours is cheaper than most. I'll trust my assessment of structural design of my travel trailer frame. The frame of a travel trailer is one part of a system. The floor, walls and roof all add or subtract to the strength of the frame. The processing and the shipment of frame also have lots to do with quality of the final product. Sorry about the problems that you have had, but I doubt you even understand the root cause of the issues.MM49 wrote:
I was fixing the water tank support on my Sunnybrook and noticed it was a Dexter frame. I am very impressed with the design and manufacturing. Every suspension point is reinforced with a well designed plate. The floor trust use round rod in cross pattern simular to comercial buildings. The I beams are a light weight RV design, not and assembled beam. I expect good performance for this unit.
MM49
One manโs experience with Sunnybrook and Dexter framesโฆ
Fixing the water tank supports seems to be a popular pastime on the Sunnybrook trailerโฆ
also its the weak Dexter frame that allows too much flex in the trailer causing things likeโฆ falling water tanks, plywood becoming ripped loose from the roof trusses, siding buckling and cracking above the door and in the same area on the opposite sideโฆ then more importantly there were the unexplained sticking doors that needed the jaws of life to get open, or just wait a half hour and it would open like nothing was wrong, to the annual door replacement because they were bent too bad to reinstallโฆ all caused by the weakness in the impressive looking Dexter frameโฆ
MM49
โApr-23-2014 03:39 PM
MM49
โApr-23-2014 12:28 PM
filrupmark wrote:
Everybody thinks Lippert frames are bad. The fact of the matter is that Lippert builds frames to the manufacturers specs. Some engineers are good and some are stupid. Hope you dont purchase a trailer that had a stupid tightwad engineer.
โApr-23-2014 11:59 AM
MM49
โApr-23-2014 11:02 AM
โApr-20-2014 06:30 AM
coolbreeze01 wrote:MM49 wrote:The connection is the "Dexter" frame.
MM49
MM49
What about Jayco?
โApr-20-2014 06:12 AM
โApr-20-2014 06:03 AM
โApr-19-2014 02:11 AM
โApr-18-2014 08:03 PM
Jayco23FB wrote:
Does anyone know what brand of frame is under my 2010 Jayco G2 23FB?
I keep here concerns about Lippert frames......just wondering.
Thanks
โApr-18-2014 04:44 PM
MM49
โApr-18-2014 02:03 PM
โApr-18-2014 01:45 PM
โApr-18-2014 11:23 AM
