What causes soft floors
mkenyon2
What causes soft spots in floors? What can be done to prevent that? How serious is it?
I'm guessing soft spots are areas where the subfloor (plywood or OBS) has gotten moisture and weakened. I'm wondering if it happens more when parked on a grassy lot vs a paved area?
I also understand that how serious it is is subjective to the area that's gotten soft and the model of trailer.
My question comes up as I look for a used travel trailer and have seen some nice ones with soft spots.
MK and my Wifey from PA
TV: 2011 Ford F150 SuperCrew 4WD (V6 3.5L/213)
Trailer: 2013 Heartland Trail Runner 25 SLE
We've only camped in 2 states? Quick, pack the trailer we have to CAMP!
37 REPLIES 37
Gdetrailer
For the record.. I HAVE repaired the subfloor on my 1984 TT which was damaged from water leaks that the previous owner didn't fix. The subfloor on my 1984 IS 1/2" plywood.
Yes, it IS GLUED to the foamcore below it, but I was able to remove the damaged plywood between the wood studs. Wasn't pretty but it most certainly is fixable. To add replacement plywood I had to add some supports for the ends of the plywood, easy enough, just dig or cut out some of the foam and lay in the wood reinforcements.
The big problem is not the "sandwich" but the fact that many manufacturers are not using 1/2" plywood as the subfloor, instead they have thinned that down to 1/4" or less.
Lantley
Gdetrailer wrote:
Lantley wrote:
Does it matter which part of the sandwich is faulty. If it's the thickness of the plywood portion or the density of the foam either way the product loses its rigidity and creates soft spots.
Why the sandwich fails is less important than the simple fact RV manufactures are continuing to use questionable products and questionable construction methods. The consumer ends up holding the bag of soft floors!
I agree sandwich construction is generally found in "Lite" units.But I don't believe it's exclusive to light units.
The real bottom line is units that don't use sandwich construction are generally more costly which makes those units less desirable to $$$ focused consumers.
Your avoiding my question :h
Please point out the exact models and manufacturer brands which does not use a "sandwich" floor construction.
If you can't point out any models, then say so and then stop referring to that method as sandwich..
Sandwich is not the proper term for the construction of composite floor, wall or roof.
I 'm not concerned that its the proper term. This is not a grammer or construction forum. I'm using the term sandwich because its the proper description. Everyone reading this including you understand what I'm saying in terms of how the floor is constructed.
By the way I'm sure I'm not the first or last to describe the floor as a sandwich.
For the record Artic Fox states in their brochure that they use T&G plywood as their sub floor decking.
Sandwich construction is pouplar but it is not the only method being used for floor decks. But again many are not aware of the eventual soft floor issue.
Many are not familiar with other construction techniques and materials.
They simply are not aware: of the need to upgrade to something better, or gamble with the consequences of sandwich construction.
Soft spots typically don't occur instantly but they develop over time.
By the time a unit has mutiple soft areas the warranties have expired and the manufactures'are off the hook.
Leaving the unsuspecting buyer holding the soft floor bag. That tale repeats itself many times.
Gdetrailer
Lantley wrote:
Gdetrailer wrote:
For the record.. The SUBFLOOR thickness and type of material IS the problem, not the construction method.
Yes, some manufacturers skimp on the subfloor thickness and type of material on some models and that IS the problem.
It's not simply a subfloor problem. Simply replacing plywood is doable.
However it's replacing the sandwich...multiple layers that complicate the repair.
Nope, wrong you are.
Here is a illustration of the "sandwich floor".
Click For Full-Size Image.
That is taken from my 1984 brochure.
Please kindly note the critical area that the red arrow is pointing to.
That is the subfloor and that IS where the problem begins at.
Lantley
Gdetrailer
Gdetrailer
wowens79
I've got one with the sandwich floors and it is awful. I've got soft spots in all the high traffic areas. I had no clue about this when we bought the camper. I would avoid it at all costs.
I'm wanting to go to a 5th wheel, but really dread trying to sell this one. I've looked at repairing, but it looks like it will be a huge undertaking.
2022 Ford F-350 7.3l
2002 Chevy Silverado 1500HD 6.0l 268k miles (retired)
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
Lantley
Gdetrailer
Can you point out the specific models of RVs that use T&G subfloors and conventional home floor structure?
I have never seen such setup in any RV I have been in so I highly doubt what you say is true..
Been in RVs from the 1960's and up and so far none of those were constructed like a conventional home floor with T&G.
The problems you state with sandwich floors is not 100% true in all cases. The problem stems from manufacturers reducing the thickness of the sub floor. I have a 1980's TT which has 1/2" thick plywood as a subfloor, but it is also glued (laminated) to the Styrofoam insulation below it and under the Stryofoam is as 1/4" plywood layer.
Modern RVs instead of using 1/2" plywood subfloor are using 1/4" or a bit thinner MDF or strand board to save weight and expense and that IS the real problem.
The only way you can avoid the thinnest subfloors is to make sure you are not choosing the "Lite" versions but then it now is heavier than what everyone wants to tow with can tow and not to mention far more expensive..
MDF and strandboard can no longer be avoided, the cost of real plywood will drive a lot of consumers away from the RVs..
Lantley
I hear you Hunting Dog and I sort of agree with your upgrade what you can philosophy. Except sandwhich floors are sort of structurally compromised from the start. The foam will not remain ridged for the lifetime of the RV. It is inevitable that soft spots will develop in high traffic areas.
In some cases there is not a lot you can do in certain scenarios to repair this issue.
Sandwich floors are very common but they are really something to avoid.
In order to avoid the sandwhich floors you have to migrate to a more expensive unit. To complicate it even more, sandwhich floor are inherently structurally compromised. The floors become even more a liabilty when they are not supported properly or compromised by a duct are wiring chase.
Many are not aware that the sandwich floors are a liabilty, they don't understand why its important to have t&g sub flooring on their must have list.
To their credit sandwich floors are lightweight and provide insulation, but if the floors are not sturdy they quickly become a liabilty.
Beefing up the sandwich floors can be a simple task or it can be very involved.
Avoiding the floors from the start is the best solution. Convincing manufactures not to use sandwich floors is a better solution. But Huntingdog is probably right. SAndwhich floor are heere to stay for the foreseeable future
Huntindog
Soft spots maybe the result of moisture from a leak. They may also be the reult of poor construction techniques and inferior sub floor material.
They can easily be avoided however the manufactures have to committ to designing and building a better unit vs. building units with known construction flaws and selling them anyway.
On the other hand consumers cannot me so price focused that they refuse to buy the prperly built unit, because they don't wnt to pay a few grand more to get a unit that was built right from the start.
All true but, I do not see that happening in my lifetime.
So my approach is buy a unit that has the things I cannot fix or upgrade, modify etc. such as a stout frame, and then mod it to suit me.
As it happens, these things also make it easier to sell for top dollar when the time comes. I have sold 3 TTs so far. In each case, the first one to look at it bought it, and for more than I was expecting to get.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
Lantley
tinner12002
The soft spot we have is due to the heating duct and the way Keystone cuts/installs it into the floor. Its right where we step down off the steps from the bedroom/bathroom and into the living area. I've read where others have had the same issue, same spot.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
Wyldfire
jdc1 wrote:
Yep. Dryrot. Usually found under sinks, in front of shower/toilets, and sometimes a window or vent left open. Very seldom does it happen from below.
I would disagree. On some brands of newer trailers using foam sandwich floors that are only protected with darco. Rocks get thrown up and pierce this lightweight material. Driving in rain causes water to be thrown in the holes leading to break down of the wafer thin wood bonded to the foam. Mold moves in causing further damage.
kellem
Worse case scenario is a roof leak....water seeping down the walls and absorbed by floor.
When looking at used trailer's it would be prudent to avoid any and all trailer's that have soft floors. Imo
