MargaretB wrote:
We have abandoned our plan to buy a small hybrid and are looking at a number of hard-sided TTs, in the 22'-26' range. We have to buy a new vehicle to tow it with and are thoroughly confused. We've decided that we want an SUV instead of a truck. We've been looking at used vehicles.
A dear friend who tows a 22' Airstream does so with an MB diesel and insists that diesels are the only way to go, because they develop full torque at 2000 rpms instead of 3500 rpms for non-diesel cars. We can't afford an MB, so he recommends a VW Touareg.
We love he idea of smaller "regular" SUV because whatever we buy will tow for maybe 5-10% of the time and b a town car the rest of the time. A local dealer says that the Touareg certainly has the torque to tow at 6000-7000 lb. trailer, but probably does't have the braking power to handle it on a downhill slope. Touareg diesels are incredibly hard to find - we've found three used ones in all of California and can't afford a new one.
We've been looking at Toyota Sequoias and Ford Expeditions, which aren't diesel. Our friend is pooh-poohing those options.
We're hoping not to add another vehicle to the mix, but we're hearing good things about the Tahoe and the Silverado.
So my question is - what do you drive to tow a TT in the range we're considering? How is it working for you? Is there anything else you wish you'd bought instead? What are your thoughts with regard to diesel vs. gas?
OK, to start, I don't think your friend really has a clue. I think he feels what he does is the only way, and the right way. I disagree with that.
Myself, I would never own a Volkswagen Touareg. They are foreign vehicles that aren't made in the USA for one (I support American labor). The next is that they are one of the most unreliable vehicles made. The Volkswagen Touareg is not recommended to use a weight distribution hitch which limits you to really light tongue weights of
only 617 lbs even though the max tow rating is 7716 lbs!Using an average formula to calculate your hitch weight (13%) will help find your max tow weight. Also most people load their vehicles 1500 lbs to 1700 lbs over the "BROCHURE" dry weight. Dry factory delivered weight is usually 200 - 300 lbs heavier than the Dry "BROCHURE" weight, when options are added.
So take that 617 lbs and divide by .13 to see what total loaded trailer weight you can have on the hitch. That is 4746 lbs. Now subtract 1500 lbs from that to give you a brochure weight of only 3246 lbs !!!!
Yes, I been there already with my weak 2005 Nissan Pathfinder (made in Tennessee
๐ ) with it's low 600 lbs tongue rating.
You are pretty much stuck to a Pop Up camper or very VERY small travel trailer as the Forest River R-Pods.
Your buddy is most likely overloading his hitch.
Now thanks to the Touaregs incompatibility to use a weight distribution hitch, weight is likely overloading the rear axle while not enough weight is on the front axle especially during wet driving. The light weight on the front axle could lead to steering failure on wet slick roads.
The Touareg would be the last vehicle I would ever buy to tow a travel trailer. For a Pop Up, yes, not a travel trailer.
Obviously the toaregs tow rating is for "BOATS" .. The 617 lbs is right at the average 8% tongue weight of a boat/trailer and boat trailers don't usually use weight distribution hitches (although they should over 500 lbs).
Now you didn't specify the actual trailer size you wanted, 22' to 26' bumper to tongue (which is the correct way to size a trailer) or the guessing on the model number which is usually 3' to 5' shorter than the actual length of the trailer?
A true 22' bumper to hitch travel trailer will be extremely hard to find with such a light tongue weight. A 19' Ultralight, Ultra-small trailer as the R-Pod, 'could' work.
Also keep in mind that you'll likely need at least 1200 lbs of payload for a small family of 3 or 1400 lbs for a small family of 4. Most crossover SUVs in the touaregs size offer only 800 lbs.
I would suggest a large Expedition XL or Suburban to tow a 26' trailer with a very VERY good Anti-sway weight distribution device, as Pro-pride, Hensley, Reese Strait line or maybe even a Equ-ali-zer brand.
You need the best anti sway protection because of the short wheelbase of the Suburban or Expedition XL. The shorter versions of these are best left to shorter trailers. Also make sure you have at least 1500 lbs of payload for a small family and heavier tongue weight of a 26' trailer. The Suburban and Expedition XL may be less than that pushing you to a 3/4 ton Suburban.
Now back to that touaregs diesel. You need Horsepower just as much as torque, to keep you going and that diesel engine is anemic. Torque gets you going and horsepower keeps you going. With the new GM 5.3L and Ford's 5.0L and Ecoboost, you'll have plenty of torque to get the job done and with reserve. Plus you'll have better than 100 more horsepower than the little VW 3.0L Diesel's 240 Hp.
Your best bet for a 26' bumper to hitch trailer is a full size crew cab pickup (appropriately configured) if you want to pull a 26' trailer. But if you have the payload capacity and a very good anti-sway hitch, you may be able to get by with a Suburban or Expedition XL. I wouldn't suggest any other SUVs as they have very short wheelbases and lower payload.
2019 Ford F150 XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 9.75" Locking Axle, Max Tow, 1831# Payload, 10700# Tow Rating, pulling a
2020 Rockwood Premier 2716g, with a 14' box.
Previous 2012 Jayco Jay Flight 26BH.
