What do you use to lube your stabilizer jacks?
Wrace
What do you use to lube your stabilizer jacks, both the threaded rod part and the various pivot points in the mechanism?
Thanks
52 REPLIES 52
campigloo
I use the same products rbpu uses and the same wash method. I have found that chain lube works and lasts a little longer than some.
Community Alumni
Not applicable
I spray them with a silicon lubricant.
rbpru
I use about any spray on lube. It all seems to wash off in the next rain storm I drive through. :W
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
beemerphile1
WD40 a couple times a year. Helps to prevent rust and provides a little lubrication without making them oily/greasy.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
n7bsn
Old-Biscuit wrote:
Dry graphite spray....goes on wet then completely drys in minutes.
Stays on, lasts and great lube
Yup, furniture polish is NOT a lube, it's a wax finish. If you this it doesn't attract dirt, ask your wife ๐Ÿ˜‰
BTW, the dry "teflon" works well too
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Old-Biscuit
firedguy
Pledge furniture spray on the threads. It doesn't attract dirt.
2011 Chevy Silverado 3500 1LT trim, DRW, Duramax/Allison 6spd.
2011 Jayco Pinnacle 4slides, 40ft, 15000lbs GVWR.
coolbreeze01
I use 3-IN-ONEยฎ Garage Door Lubricant. Good stuff.
2014 Sandsport 26FBSL
