Apr-21-2021 06:15 PM
Apr-24-2021 06:58 AM
Apr-23-2021 09:24 PM
Apr-22-2021 06:51 PM
jimh425 wrote:toedtoes wrote:
Sheesh. You guys need to get out more. Really, arguing if a converter is actually a converter?? 😉
We really need the ability to like a post. 😉
Apr-22-2021 03:34 PM
garym114 wrote:
Primary purpose of a converter is to supply 12v to RV from 120v AC shore power.
An inverter creates 12v AC from 12v DC.
Apr-22-2021 03:05 PM
Apr-22-2021 02:30 PM
Apr-22-2021 02:03 PM
Apr-22-2021 01:51 PM
Apr-22-2021 12:42 PM
Apr-22-2021 12:19 PM
Apr-22-2021 11:56 AM
Kayteg1 wrote:valhalla360 wrote:
As far as the name, you could as easily say an inverter CONVERTS from 12vDC to 120vAC and it's true ....
You can't convert AC from DC.
You have to invent AC current using electronic devices and then you can convert to desired voltage.
Over the years converters went via several designs.
Back in 1980's they would supply 12VAC for RV lights and water pump, when small DC circuit would charge the battery and operate radio.
Then some designs put 12VDC converter parallel to the battery, some disconnects the battery from RV when on converter.
That surprised me lately as 20 yo converter was showing 18V on new digital gauge.
Took few forum experts (not on this forum) to figure out that converting AC with electronic circuit, the voltage spikes high for microsecond, before it levels at ca 12V.
Analog meters will not register it, some digital multimeter will not register it, but cheap meter that come with lighter socket does.
Apr-22-2021 09:26 AM
Apr-22-2021 09:14 AM
Apr-22-2021 07:21 AM
mkirsch wrote:valhalla360 wrote:
It's a battery charger. Never made sense why RVs use a different name.
Yes, you can draw off it directly but you can do that with a battery charger too.
That is not entirely correct. You cannot (safely) draw directly off of a battery charger because it is not regulated. A battery charger's output varies depending on load. It can start out at 19V or higher with a very light load (or on the high-Amp charge setting) and drop to below 11V with a heavy load.
IF what you are trying to run isn't terribly voltage-sensitive, then sure. However sensitive electronic devices looking for a 12V input are going to have problems on raw 19V+ from a battery charger.
A converter has a regulated voltage output. It is called a converter because it CONVERTS 120VAC to 12VDC, the opposite of an inverter which INVERTS 12VDC into 120VAC. Not all converters are battery chargers, as pointed out above.
