Apr-27-2014 03:17 PM
Aug-22-2014 12:51 AM
I use a variety of sealants in my work life, including the best GE 100% silicone money can buy. I've used it for years and know the properties. I don't use it for sealing anything exposed to exterior weather. Today, there are a variety of sealants that outperform silicone and will not degrade from UV. The urethane caulks are good sealers for everyday mundane tasks like siding joints and household use. I use acrylics when painting because of fast dry time and good paint bonding. Geocel, parent company of Proflex RV makes different sealers for mobile applications. Their tripolymer sealants have the characteristics that we want in an RV sealer, good bond, high elongation rate, and durability. You definitely should not take my word as gospel, experiment for yourself. Take pieces of aluminum and put beads of different caulks onto them. Put it out in your backyard for a couple of years and go back to see what has occurred.
Hi Westend,
Just curious, were you using the good quality 100%, exterior grade, clear silicone calk? I would agree lower grade semi-silicones do not provide good performance (or ones not designate for exterior use), but the calk I buy from Lowes is 100% silicone, exterior grade and I think has a 5+ yr warranty if I remeber correctly? I'd have to check. Not to say I'd trust it that long, I still reccomends checking all calk joints several times per year regardless of what you are using. The calk I use has good resiliance to weather. I have no complaints with it.
Aug-21-2014 10:20 PM
Aug-21-2014 12:37 PM
Aug-20-2014 02:30 PM
Aug-20-2014 01:54 PM
westend wrote:
I would suggest that anyone thinking about using silicone sealers should put a small bead on a surface and let it sit out in weather for a couple of years. I think you will find that it deteriorates with age and UV exposure. It's an excellent sealer when used between two surfaces held in compression (like metal to metal covers and such). My experience is that it won't stand up to weather exposure.
Aug-20-2014 01:07 PM
Aug-20-2014 01:02 PM
Gaffer222 wrote:donn0128 wrote:
The only clear sealants I know of are silicone, and silicone is so NOT recommended for use on an RV.
Not recommended by who? Many manufactures use silicon sealant as well as dealer service departments. I have never had an issue using silicon on my campers.
Aug-20-2014 07:40 AM
Aug-19-2014 05:11 AM
Aug-18-2014 09:48 PM
Aug-18-2014 06:01 PM
Aug-18-2014 11:34 AM
Aug-18-2014 09:06 AM
Apr-27-2014 05:12 PM
DB2BRMI wrote:
OP: I agree - Quad is a good caulk and I get it in clear at Ace Hardware.
DRB
