What material is my Lance TC SHOWER made of
Geterdone
My Lance 2013 model 1172 has a crack in shower wall about 8”. The crack is on wall we’re faucets are and am not sure how it got cracked. I would like to attempt a repair but am not sure if it is actually plastic, acrylic, or fiberglass. Would a plastic welder that repairs cracks in kayakswork? So I would like to know best way to approach this repair so that is not too unpleasant to look at. Can it be replaced? If so how? If I do get it repaired is there a contact paper that can be used to dress it up over repaired crack?
All comments welcome.
Thanks
Steve and Patti, 2014 Ram Duelly, Longhorn Laramie, Lance 1172 solar,Genset, torklift super hitch, and tiedowns, Bodiak front hitch,Polar Kraft boat when trailered.
2 REPLIES 2
wnjj
According to Lance's brochure for 2013, the wet bath models were fiberglass so it's likely the dry bath shower is as well.
https://lance-camper.s3-us-west-1.amazonaws.com/docs/brochure/LANCE_Camper_2013.pdf
QCMan
Nomad III
Nomad III
Most in travel trailers have acrylic and your is probably acrylic too. I don't think they would change material because it is a truck camper. You may have to get behind it to glue something on to stabilize it and then gouge out a groove at the surface to fill in.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
