Poohper wrote:
Hi,
We will be buying a new truck this year for towing my TT and I want something stronger than our 2007 Ford F250 Diesel. It seems the weight we were given for the TT by the dealership is wrong and it seemed our trailer was always a little too heavy by the tongue for the F250. My husband just says as long as it pulls don't worry about it but if we are getting a new truck I want it to be right this time. I'm not sure if we will get diesel or gas next so I want to also know what most people drive towing TT's. I'm knocking out Ford trucks as I don't think they keep up with the rest. Thanks!
I'd be real suprised if you aren't well within the towing capabilities of that truck. I pull a 32ft outback with a weight of almost 10K lbs and 1400-1500 on the hitch. On both my 04.5 Silverado duramax cc 4x4 and my 2015.5 Denali duramax cc 4x4 I am comfortably within all the ratings. There is no reason to believe your 2007 wouldn't be similar. All this is ASSUMING you are using a WD hitch, which you MUST use with the big a trailer. Otherwise you will likely be well over the weight carrying limit of the truck reciever. they are often rated in the 750lb or less weight carrying but 1500+ lbs weight distributing.
you might want to either yourselves or someone who knows WD hitches go over your setup and make sure it is set up properly. Hint.... most trailer dealerships do NOT set WD hitches up properly. usually way to light on the bar tension.
So....... I'd do some checking before jumping ship. And power wise again the 2007 should be just fine for towing. Heck it has more HP than my 04.5 did and that truck would easily 6% grades at the speed limit.
Now if you really want a new truck, go look at all of them and decide which one YOU like best. Your going to be using it, not someone else. And really all 3 make very good trucks now, IMHO it's more personal preference than anything else. Our son has work trucks, has a silverado as his own, truck had a dodge and now a ford work truck. he can list likes and dislikes on all 3 for what HE wants. But as he says, they all are good trucks.
2011 Keystone Outback 295RE
