Sep-09-2013 01:50 PM
Sep-09-2013 06:05 PM
Sep-09-2013 05:48 PM
Sep-09-2013 05:34 PM
TucsonJim wrote:
I've got many, many thousands of miles on my FWs over the years. I've never lost a bearing. This is detective work. As posted above, it could be an inept installation job, incorrect application of grease, or the wrong grease.
But something else to consider is who replaced your bearings in the first place. If your bearings went out in the past, and they were replaced, then the race SHOULD have been replaced too. If they just slapped a new bearing in, but didn't replace the bearing race (the part the bearing mates with) then another failure is pre-ordained. Other things to consider were if they also replaced the grease seal. If not, the grease could have heated up and leaked past the seal which would leave a dry bearing.
Sep-09-2013 05:31 PM
westend wrote:byways wrote:Don't worry. Once you have new bearings and they are installed correctly, you should have years of towing ahead. I have the original hubs on a '72, that's 41 years, if my math is right.:)coolbreeze01 wrote:
Not caused by speed, that's for sure. Find a shop that knows what they are doing. Good luck.
thank you. I am so frustrated right now...and skittish about towing.
Sep-09-2013 05:30 PM
Shadow Catcher wrote:
There are bearings and then there are bearings, they come in different grades and from different countries. The ones that came with my Dexter axle were from China and I replaced them with SKF. I also used Amsoil synthetic grease and checked the castle nut adjustment my self.
Sep-09-2013 05:28 PM
Slownsy wrote:
He posted that he had new 6000lb axles installed but I don't se how he new they were properly greased unless he did it himself after installation. He dos not say so.
Sep-09-2013 05:01 PM
Sep-09-2013 04:44 PM
Sep-09-2013 03:53 PM
Sep-09-2013 02:49 PM
Sep-09-2013 02:37 PM
Sep-09-2013 02:36 PM
Sep-09-2013 02:16 PM
Sep-09-2013 02:14 PM
Sep-09-2013 02:11 PM
69 Avion wrote:
As long as I have been building trailers, I haven't gone through that many bearings. Are you packing them? If so, how tight are you setting the nut? That is probably the issue.
