White rubber roof life and replacement cost?
slacker_cruster
How long does the white rubber roof last and how much for replacement cost?
Mine roof is near 7 years old. Some of the caulk cracked so I recaulked it. It is outside 365 a year and never cleaned it.
If I get it re roofed down the road I will take out the escape hatch on the Northstar's roof. The shade gets to 120 degrees in the summer. I've blocked it off for all practical purposes, so never use it other than to get irritated at when I look at it.
17 REPLIES 17
pianotuna
Nomad III
Nomad III
Scrubbing it may reduce the lifespan. Leave it alone other than caulking.
Regards, Don
slacker_cruster
I guess I've been lucky only having to re caulk once. Since I never cleaned it do you think it is too late for mine?
donn0128
With care it should last 12-15 years. Cleaning, inspection, and recaulking should be done twice a year.
