โJul-05-2013 07:40 AM
โJul-16-2013 07:14 AM
'15 Chevy Silverado 2500 HD
'18 Forest River Avenger :C "Dolci"
Kipor KGE3500Ti
CHECK OUT THE RV.NET BLOGS!!
โJul-16-2013 03:09 AM
Beachums wrote:Huntindog wrote:kedanie wrote:
How about one of you guys try being the bigger man and just walk away from a fight that neither will win!!!!!!!!!!!
Enough!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Actually I won the day I walked away from ST tires.
There sure are a few egos on this thread, I keep going back to the title to make sure I am in a tire thread on a RV site..... You would think that the topic would be of much more consequence with the tone of most of these posts.
Also, You lost before you even finished the first word with that red font....... Are you trying to be a mod or something?
I guess someone smarter than me wouldn't even bother to post this opinion, but what can I say.......I guess I need to go on a camping trip or something
โJul-16-2013 01:08 AM
โJul-16-2013 12:16 AM
โJul-15-2013 09:01 PM
โJul-15-2013 06:34 PM
JIMNLIN wrote:
I like yanking JJs chain as he gives us long impressive flowing posts like a couple of his posts.
IMO we should all be working together and give folks looking for a better brand or tire type some input on what actually works out here instead of backing a tire company into the liability corner.
Hell I can ask any LT tire maker the right question and they will have to give the usual CYA liability answer like the BFG and Vanco email responce.
They also will give a trailer owner a thumbs up simply by wording the email/1-800 differently.
Its all about ones agenda.
Most folks understand that ploy.
โJul-15-2013 06:00 PM
โJul-15-2013 05:34 PM
โJul-15-2013 04:28 PM
โJul-15-2013 04:23 PM
โJul-15-2013 04:20 PM
โJul-15-2013 03:18 PM
JJBIRISH wrote:This I sorta agree with. But one doesn't have to limit themselves to the exact everything. Many times a bigger size etc. WILL work just as good or even better.Huntindog wrote:JJBIRISH wrote:JIMNLIN wrote:
The rules are pretty simple, the replacement tires must equal or better the tires listed on the vehicles tire placardโฆ
JJ, knows as well as most folks that the tire placard is a recommendation only. When you use the word "Rules" it implies some kind of law. There is no enforcement law that says the replacement tires have to be the same type listed on the placard.
The only enforceable law is roadside. They look for a DOT number and the tire capacity to match the vehicles axle ratings.
if your trailer came with ST225x75x15 in LR D @ 2540 lbs. capacity on the placard you canโt just say you can use a Wrangler HT in LT215x15 LR D @2090 lbs. capacity or in a LT 235x75x15 LR C @ 1980 lbs. capacity, which is what is often recommended in the forums for this situationโฆ
Incorrect.
What I and others have recommended and are actually using is those two 1980-2080 lbs capacity LTs you mention for replacing a ST205/75-15 C at 1820 lbs capacity.
Actually you are incorrect, I know you insist this is not true and have posted so even for my stateโฆ
โJack, you and FastEagle are playing to the tire placard liability thing simply by constantly bring up the issue just like your last post referring to certain tires that have been mentioned wouldn't pass your state inspection. Baloney. FastEagle has tried that trick also.
As long as the tire has enough tread depth and enough load carrying capacity/etc it will pass anyones state safety inspection requirement or even pass the annual fed safety inspection required for a commercial trailer/all vehicles regardless of tire type.โ
The PA inspection sayโฆ the mfg. that being the trailer mfg. as the one required to correctly placard the vehicleโฆ there are other provisions in the law pertaining to the trailer tires condition and tread also, but I am not about to search them all out right nowโฆ
(g) Tires and Rims - The axles of a vehicle
specified under this subchapter shall be
equipped with the number and type of tires
and rims which have a load rating equal to
or higher than those offered by the
manufacturer.
If the placards are only recommendations why do they deserve to be safety recalled so often for having the wrong information on the placardsโฆ
There have been recommendations made on the forums based on claimed trailer weights only that have had nothing to do with the trailers placard weights or even the axle weightsโฆ
While I havenโt ever made the claim that the tire type must be the same and that is misquoting me, the inspection law does in fact say the same number and type and load rating equal to or higher thanโฆ
You consistently accuse myself and others of boxing the tire builders into a corner when they are asked for information only because it donโt agree with your personal positionsโฆ
One posters response
We do not recommend using light truck tires on trailers that specify ST tires. If the trailer manufacturer calls for ST tires, it is important to replace with ST tires in order to maintain the load requirement.
Thank you for choosing BFGoodrich.
Your reply
โThe OP backed BFG into the liability corner with that type question. He will get the same answer from any LT or P tire maker by asking for a direct replacement for a ST tire.โ
And
โIf your really interested in using LT tires don't back the tire makers or their dealers into the liability corner. โ
Obviously you donโt think these are big boys that know how to answer for themselvesโฆ
My e-mail reply from continental tire
Thank you for contacting Customer Relations at Continental Tire the Americas, LLC.
We no longer manufacture ST tires, and the Vanco line is not a suitable alternative.
We would recommend searching for a dedicated ST tire line.
And your reply
โYou badgered Vanco with the more canned questions until they gave you the answer you were looking forโ
None of these people according to you know how to answer normal questions to their help lineโฆ no badgering, no pushingโฆ the answers just donโt back up your opinions...
If you want the answer you are looking for according to your words, be sure to softball your questions
If these companies canโt stand tall on their own feet and recommend a LT tire, no, their LT tire even one with sufficient load capacity as a replacement tire for a ST tire why should I or anyone else assume itโs the thing to do, or assume you and others are their secret information outletโฆ
And this coming from me someone that generally donโt like the ST tire or their specifications, or their DOT certification requirements, and have voiced this many times, and believe the LT tire is a better tireโฆ someone that if not for the Maxxis brand having proven itself to me, would be faced with a serious personal dilemmaโฆ.
Stop the nonsense already. You pretty much admit that LTs are generally a better tire...Except for the beloved Maxxis, which has availability issues....
What will you do when Maxxis lowers their standards to the same as the rest of the ST crowd.
They seem at the present time to build to a higher standard...But all corporations are under constant pressure to increase profit. You say yourself that the govt. standards for ST tires are much weaker than for LT tires... That means at any moment that Maxxis can, and one day likely WILL lower their standards in order to remain competitive.... And they will do this overnite with telling you or all the people you are trying to convince to use those tires.
Anyone that actually bothers to read the testing standards required of LT tires and then reads the standards for ST tires, will be amazed at the difference. And all this debate will be over for those that do.
The only way to be sure that a tire will meet the higher LT standards is to BUY LT tires.
There is no nonsense hereโฆ I have not generally admited the LT is a better tireโฆWhen you admit that the testing criteria for LT s is higher....It is the same as admitting it. I have stated that before and have never stated any ST tire was a better tire including the Maxxisโฆ I have said Maxxis is the best ST tire...
No one has complained about the testing and certification requirements of the ST tire more than I, including youโฆ or the fact that Maxxis is voluntarily building well above those minimum standards, leaving me with my last choice in a ST tire since no Chinese tire of any type will ever grace my trailerโฆ And you never bring up the downside to Maxxis...
That it does seem to be a good ST tire, but has availability issues. Post after post on here of people having to order them and wait. This is OK I guess if you don't mind having to wait. But it can be really inconvenient if a tire experiences a road hazard away from home and needs replacing pronto.... And ALL tires, even good ones can have this happen. in my last post I also admitted if not for the Maxxis I would have a real dilemmaโฆ reading only what you want againโฆ Not at all. You still do have a dilemma... You just refuse to recognize it or admit it.
I did actually read all the testing procedures for both the ST tires and the LT tires and have posted my interruption of the results many timesโฆ
Have you actually read them yourself or only what myself and a few others much smarter than I have posted about themโฆ I assure you itโs not fun, interesting, or light readingโฆ. Yes I have read them.
Your and you cohorts that just profess to buy and change to LT tires are merely putting words in a post, because for the TT there just arenโt a lot of good choices for us like there are for the bigger trailers and 5ers, and when you find a tire for many more it just wonโt fit under the trailer with the correct clearancesโฆ
So you solution is to try to erect obstacles to solutions that can work for people. Getting email after email answers that fit your narrow view and saying that it can't be done....
You guys know all of this of course, and just try to display your superior wisdom because you were fortunate enough to be able to switch but lacked the wisdom to buy the trailer with them alreadyโฆWe have covered this before. Changing tires is a easy fix in order to have a TT that fits my needs in other ways. Moving walls and installing another bathroom etc. Not so easy to do.
So I think I had PLENTY of WISDOM.
Like it or not, there are both legal and liability concerns that you choose to ignore and deny even exist, but I will continue to point them out and we can continue to disagree, and thatโs okโฆ readers need to hear all sides and make their own informed decisions on what risk they are willing to acceptโฆ
Are you a lawyer? If not, shush. After all of your quotes about listening to the "experts in the field", you should understand that you have no expertise in the law unless you are a lawyer.
It doesnโt matter if the LT is a better tire if it isnโt made in the right size, installed on the right rim, or donโt fit under the trailer correctlyโฆ
โJul-15-2013 02:59 PM
Atlee wrote:
After this post, I'm done.
However, the googled link you gave plainly says towing speed is "As Posted".
Yet you've been saying the trailer towing speed in Virginia is unposted and is 55mph.
And one other thing. Why would Virginia limit travel trailer speed to 55 mph, when all other towed vehicle speed limits, including 18 wheelers, is what ever is posted on the highway being traveled, and unposted speed limits on Virginia secondary roads is 45 mph?
โJul-15-2013 02:18 PM
Incorrect.
manufacturer.
Your reply
And
And your reply
