โJul-05-2013 07:40 AM
โJul-15-2013 12:30 PM
JJBIRISH wrote:JIMNLIN wrote:
The rules are pretty simple, the replacement tires must equal or better the tires listed on the vehicles tire placardโฆ
JJ, knows as well as most folks that the tire placard is a recommendation only. When you use the word "Rules" it implies some kind of law. There is no enforcement law that says the replacement tires have to be the same type listed on the placard.
The only enforceable law is roadside. They look for a DOT number and the tire capacity to match the vehicles axle ratings.
if your trailer came with ST225x75x15 in LR D @ 2540 lbs. capacity on the placard you canโt just say you can use a Wrangler HT in LT215x15 LR D @2090 lbs. capacity or in a LT 235x75x15 LR C @ 1980 lbs. capacity, which is what is often recommended in the forums for this situationโฆ
Incorrect.
What I and others have recommended and are actually using is those two 1980-2080 lbs capacity LTs you mention for replacing a ST205/75-15 C at 1820 lbs capacity.
Actually you are incorrect, I know you insist this is not true and have posted so even for my stateโฆ
โJack, you and FastEagle are playing to the tire placard liability thing simply by constantly bring up the issue just like your last post referring to certain tires that have been mentioned wouldn't pass your state inspection. Baloney. FastEagle has tried that trick also.
As long as the tire has enough tread depth and enough load carrying capacity/etc it will pass anyones state safety inspection requirement or even pass the annual fed safety inspection required for a commercial trailer/all vehicles regardless of tire type.โ
The PA inspection sayโฆ the mfg. that being the trailer mfg. as the one required to correctly placard the vehicleโฆ there are other provisions in the law pertaining to the trailer tires condition and tread also, but I am not about to search them all out right nowโฆ
(g) Tires and Rims - The axles of a vehicle
specified under this subchapter shall be
equipped with the number and type of tires
and rims which have a load rating equal to
or higher than those offered by the
manufacturer.
If the placards are only recommendations why do they deserve to be safety recalled so often for having the wrong information on the placardsโฆ
There have been recommendations made on the forums based on claimed trailer weights only that have had nothing to do with the trailers placard weights or even the axle weightsโฆ
While I havenโt ever made the claim that the tire type must be the same and that is misquoting me, the inspection law does in fact say the same number and type and load rating equal to or higher thanโฆ
You consistently accuse myself and others of boxing the tire builders into a corner when they are asked for information only because it donโt agree with your personal positionsโฆ
One posters response
We do not recommend using light truck tires on trailers that specify ST tires. If the trailer manufacturer calls for ST tires, it is important to replace with ST tires in order to maintain the load requirement.
Thank you for choosing BFGoodrich.
Your reply
โThe OP backed BFG into the liability corner with that type question. He will get the same answer from any LT or P tire maker by asking for a direct replacement for a ST tire.โ
And
โIf your really interested in using LT tires don't back the tire makers or their dealers into the liability corner. โ
Obviously you donโt think these are big boys that know how to answer for themselvesโฆ
My e-mail reply from continental tire
Thank you for contacting Customer Relations at Continental Tire the Americas, LLC.
We no longer manufacture ST tires, and the Vanco line is not a suitable alternative.
We would recommend searching for a dedicated ST tire line.
And your reply
โYou badgered Vanco with the more canned questions until they gave you the answer you were looking forโ
None of these people according to you know how to answer normal questions to their help lineโฆ no badgering, no pushingโฆ the answers just donโt back up your opinions...
If you want the answer you are looking for according to your words, be sure to softball your questions
If these companies canโt stand tall on their own feet and recommend a LT tire, no, their LT tire even one with sufficient load capacity as a replacement tire for a ST tire why should I or anyone else assume itโs the thing to do, or assume you and others are their secret information outletโฆ
And this coming from me someone that generally donโt like the ST tire or their specifications, or their DOT certification requirements, and have voiced this many times, and believe the LT tire is a better tireโฆ someone that if not for the Maxxis brand having proven itself to me, would be faced with a serious personal dilemmaโฆ.
โJul-15-2013 11:21 AM
Incorrect.
โJul-15-2013 10:18 AM
EldIr wrote:Atlee wrote:
Can you tell me where you found the information stating the Virginia speed limit for travel trailers is 55 mph?EldIr wrote:Atlee wrote:
The only roads in Virginia that are unposted, as far as I know, are some of the rural small secondary roads. And as been mentioned, the speed limit for them is 55, unless otherwise posted. I know of no Virginia roads, either the interstates, US numbered roads, or Virginia primary roads that are not posted.
In Virginia, any roads in residential or business areas are 25 unless otherwise posted. On secondary roads, the speed limit is 55 for cars, unless otherwise posted.
coolbreeze01 wrote:
Unposted speed limits? 108" max trailer width in Hawaii? 96" max trailer width in Arizona? .......Amazing :S
We're not talking about roads not having posted speed limits. We are talking about a speed limit when towing that is not posted and is lower than the posted limit. Many states have a 55mph limit when towing even if you're on a 65mph or higher posted road. It is only the limit for towing that is unposted (but the law). And Virginia's max tow speed is 55mph.
Sure. Google could have told you sooner.
โJul-15-2013 09:09 AM
โJul-15-2013 07:39 AM
โJul-14-2013 09:16 PM
SprinklerMan wrote:
What rules are there for tire use ? All I have ever seen are recomondations .
Manufacturers give the specifications for the tire , speed rating , weight rating , etc . It is up to the consumer to determine what they wish to purchace . The only 2 things I have ever seen on on tires are " for trailer use only" and " not for highway use " on equipment tires .
โJul-14-2013 08:43 PM
โJul-14-2013 08:07 PM
โJul-14-2013 08:06 PM
โJul-14-2013 06:46 PM
โJul-14-2013 05:50 PM
โJul-14-2013 05:20 PM
โJul-14-2013 03:07 PM
SprinklerMan wrote:JJBIRISH wrote:ktmrfs wrote:gmw photos wrote:ktmrfs wrote:
Huntingdog. I've been looking at 15" tires and only can find LRC LT's. If you know of any 15" LRD or preferablly LRE (2800lbs) I'd be interested in knowing about it. Seems like 16" has lots of LRE, but not in 15". But LRD (2500lb) 15" ST's are very common and 15" LRE (2800lb) is also readily available.
Continental Vanco 2 ?
Goodyear cargo G26 ?
from a previous post and response from Continental, they stated the Vanco 2 is NOT TO BE USED IN TRAVEL TRAILER APPLICATIONS. Don't know the reason but the wording was very strong. Apparently the tire was specifically designed for the mercedes sprinter chassis application.
I'll have to look into the goodyear.
The exact wording in the E-mail response from Continental tire wasโฆ
And this information taken directly from the Continental tire website about the commercial Vanco tire lineโฆ
โThe growing demand for short-distance transport of passengers and goods
also leads to increased requirements so that the performance of modern day
vans nears that of passenger car.โ
โThe concept of the VancoTM Camper is to use long well-proven Vanco
technique, optimize its performance for distinguished motorcaravan
requirements and thus cater to the needs of this specific target use.โ
โThe Continental Vanco Camper tyres are part of Continentalโs Vanco tyre
range that comprises tyres exclusively for vans.โ
Could you please provide a link to continentals website that specifically states that their lt tires and NOT to be used on a trailer . And can you send links to ANY other tire manufacturers website that specifically forbids the use of LT tires on a trailer .
โJul-14-2013 07:43 AM
โJul-14-2013 02:42 AM
