โMay-28-2014 09:20 AM
โMay-29-2014 03:20 AM
โMay-29-2014 02:05 AM
โMay-29-2014 12:33 AM
bdlaise wrote:
It pays to read the trailer life magazine. In the May 2014 edition I found this tip/modification in the 10 minute tech section submitted by two other RVers. I used the same materials. These things really do reduce the bounce and wobble in the trailer. They're easy to setup and didn't cost that much to make. The materials needed are two 8 ft 2x4s, two 10-to 14 ft cargo straps *get the ratcheting kind instead of the friction type, you'll get better tightness). Cut a 45 degree angle were the 2x4 meets the top side of the frame, then determine the proper length you'll need based on the height of your trailer to the ground. I cut a 30 degree angle on mine, but you can use a 45 or what ever angle best suits your needs. The drill holes through the 2x4s for eye bolts approximately 6 to 8 inches from the end closest to the ground. I opted to split the difference and place the eye bolt in the center or just off center (towards the ground end) to keep the cargo strap out of the dirt, and provide a uniform pressure against the frame and the ground. I stained and sealed mine, for looks and protect them against the weather. Like the others RVers noted these really do make a difference.
Umm, where do the tie down straps go??
โMay-28-2014 04:44 PM
โMay-28-2014 03:48 PM
โMay-28-2014 02:18 PM
fla-gypsy wrote:
But this is a lot easier to do, adjusts to different heights, is lighter and easier to handle. The idea has been around for a number of years and was first marketed as Wayne's RV stabilizer. BTW, it works well
http://www.dyersonline.com/valterra-stabilizer-stand.html
โMay-28-2014 01:44 PM
downtheroad wrote:
Different strokes:
I like a little wobble. Keeps me mindful that I am "camping."
Otherwise I'm sitting in our rig surrounded by:
- full sized shower
- Kurig coffee maker
- 2 door frig with full freezer
- leather recliners
- Sleep Number bed
- central heating
- ducted air conditioner
- surround sound stereo
- WiFi
Well, you get the idea. Anyway, nice mod.
โMay-28-2014 12:56 PM
โMay-28-2014 12:25 PM
โMay-28-2014 11:43 AM
DutchmenSport wrote:
Interesting idea. Question though. I'm assuming you use the ratchet straps between the 2 eye bolts. When you tighten the strap, the support literally digs into the dirt (or pavement) and the other end presses upwards against the inside of your trailer frame. I see how that could make everything more stable.
But, when you break camp, how hard is is to get those supports out-of-there? If they've dug into the ground, or wedged themselves on the asphalt or concrete, can you still break them free? Or do you have to raise the trailer end to free them?
โMay-28-2014 11:15 AM
โMay-28-2014 10:47 AM
โMay-28-2014 10:31 AM
Nvr2loud wrote:Bigbird65 wrote:
I'm confused. Why would I want to add that stuff when the leveling jacks stabilize the trailer just fine for me? Must be something that I'm missing.
My trailer wobbled a lot on the (4) corner A-type stab jacks. Enough wobble when any of my children or guests (our trailer often has 9 people inside)walked around in the middle of the night, it would wake me or my wife up.
โMay-28-2014 10:24 AM
robsouth wrote:
Much ado about nothing IMHO. I don't worry about a little wiggle. Different strokes.
