โAug-19-2017 04:04 PM
โAug-21-2017 01:48 PM
โAug-20-2017 06:57 PM
โAug-20-2017 03:35 PM
Capeteacher wrote:afidel wrote:Capeteacher wrote:
In my last thread labeled Camplite I asked about towing the Camplite 21rbs with an Xterra. I got great feedback with lots of information. So I took that information and went back to searching for a TT that I can tow safely with the Xterra. I took into account the hitch weight, the GVWR and the length and these are the ones I came up with.
Flagstaff 19FBS: hitch 442, length 20'4", GVWR 3942
KZ Escape Mini: hitch 310, length 20'11", GVWR 3500
Rockwood Geo Pro: hitch 378, length 20', GVWR 3800
These all have a sofa instead of a dinette which I like and a slide which I'm waivering on getting. Xterra has a hitch weight of 500 and towing of 5000.
Comments and other suggestions are welcomed thanks.
Of those, the KZ, it's the only one likely to stay around 400-450 tongue weight which hits 500+ when you add in weight distribution hitch.
What does a weight distribution hitch usually weigh?
โAug-20-2017 02:55 PM
Capeteacher wrote:Harold Fairbanks II wrote:
Are you referring to the older real truck Xterra or the newer car-based Xterra?
The Xterra is built on the same frame as Frontier.
โAug-20-2017 01:22 PM
FrankShore wrote:
If you can, I'd have a look at Lance All their line is under 5,000 lbs and considered a lightweight:
Lance Travel Trailers
โAug-20-2017 01:19 PM
โAug-20-2017 01:04 PM
โAug-19-2017 09:11 PM
โAug-19-2017 06:52 PM
โAug-19-2017 05:43 PM
โAug-19-2017 04:46 PM
โAug-19-2017 04:33 PM
