โNov-08-2022 05:45 AM
โDec-08-2023 03:31 PM
DaveM,
Did you wire the inverter to directly drive all of the 120 VAC outlets? That's what I want to do, but when in this mode I need to: (1) not charge the battery from 120 VAC, (2) disconnect the shore 120 VAC input, and (3) disconnect the generator input. How did you accomplish this?
I just received the 120 VAC and 12 VDC wiring diagram from Northwood for my 2022 Wolf Creek 850, but they don't show the shore power, generator, or the connection to the battery!
โNov-22-2022 09:49 AM
โNov-16-2022 07:46 PM
katysdad wrote:
possibly electric jacks if installed
โNov-12-2022 06:03 AM
โNov-11-2022 06:50 PM
โNov-11-2022 05:01 PM
โNov-09-2022 05:07 AM
Davem! wrote:
I've identified all the wires (1 was from the solar charge controller and the other is for external panels if you have them) but one last thing that is a mystery.... The largest red power cable from the battery does not appear to come up under the sink and I cannot find where it terminates. I can see it go from the battery box under the floor towards the front but then it's lost. The same for the largest negative cable. Not sure what other compartments I can open up to find it!
โNov-08-2022 04:24 PM
โNov-08-2022 02:29 PM
โNov-08-2022 12:26 PM
Davem! wrote:
Hello All,
I'm wiring up an inverter and there are 4 different wires that are terminated directly on the positive terminal of the battery and some do not go through the kill switch under the sink. One is blue, the others are red. Some I've been able to trace, others are hidden in large wiring bundles. Does anyone have a wiring diagram for the 850? I've sent a request to Northwoood but so far no response. Can't find any diagrams online for the unit.
Any help is appreciated!
โNov-08-2022 11:58 AM
โNov-08-2022 11:01 AM
โNov-08-2022 08:12 AM
โNov-08-2022 06:59 AM
