3D Printing Success Story
NCMike
The jack covers on our 2014 Lance 865 had gotten very brittle and I broke one of them when I was washing the camper. After an exhaustive search, I was not able to find any OEM replacement covers for the Atwood jacks. I found someone on Etsy that offered 3d printing services and I was able to have him print/create an entire set of new jack covers for not much more than one OEM replacement cover.
OEM:
3D printed:
There is a crack in the bottom part of the 3D part. I tried to stretch it around the jack when it was very cold, I am certain if I had warmed up the plastic it would not have split.
9 REPLIES 9
BigE7686
Will you share the contact for the person who did that for you? I'm in need of replacements for my camper.
Doubleeagle999
Would you mind sharing the contact info you have for the Atwood cover? Mine is destroyed and can't find a replacement. Thanks
NCMike
I'm happy to share the contact information via PM for the person that made mine for me-no affiliation.
Could you share that info please, I need a cover also
kohldad
Good job. I think I'm going to do the same for my 2004 Lance 815 manual jacks. Want to redesign it so the pin is protected from the weather too.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
NCMike
I did not, but the part numbers were not the same.
Bedlam
Moderator
Moderator
Did you try to cross fit any of the Atwood tongue jack covers?
BurbMan
Nice!! I just found a guy on Etsy that does stainless work and had him do some custom stainless trim for our range hood. Great resource!
jimh406
Very cool. Mine are original, but so far they are holding on.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
