Feb-18-2013 03:21 PM
Jan-05-2015 04:43 PM
Jan-04-2015 09:09 PM
Jan-04-2015 08:29 PM
bka0721 wrote:
What are you using for keeping the sliding doors in place and locked from opening? Sliders "rack" unless the spring tensioner is set tight, but that inhibits sliding, but set at a medium and then bouncing over bumps n' things might skip the track. Like on a ski lift these applications have a roller on top and bottom of the top track. Is this what you have done?
Also, with work of this quality, you must be already thinking of the next project. Any hints?
b
Jan-04-2015 08:20 PM
Jan-04-2015 06:53 PM
Dec-30-2014 09:26 AM
Dec-29-2014 09:14 AM
Dec-29-2014 06:21 AM
Dec-29-2014 05:36 AM
bigcitypopo wrote:
By chance have you thought of adding a battery rack to that pod. It seems you could had 6-8 6volts there toward the front of the pod thus placing the weight almost over the axle.. It might give Ya a good boon docking edge... Prewire it for solar. And your set... Then should you ever need to off-load... The unit is self sufficent with solar and a batt bank should you need to run an inverter or such.
Dec-28-2014 09:38 PM
Dec-27-2014 11:57 PM
Dec-27-2014 03:53 PM
BoonHauler wrote:Jfet wrote:BoonHauler wrote:
I'm curious to hear how the furnace is working out for you? .......and wondering if you used the 1000 btu a foot method of sizing?
With as efficient of an envelope that you have I'd have to think that rule of thumb just wouldn't be very accurate. That's for tent trailers and alike.
Furnace! It has been 90 degrees during the day and 70 degrees at night.
Based on how well this thing is insulated, I think the near 20,000 BTU furnace will be overkill if anything. The tiny 500 watt AC certainly manages to keep the inside 25 degrees below the outside.
This fall we will know more about the furnace as sometimes it dips into the 20s during October.
I'll stay tuned......just wondering why you chose the 18k.
Dec-27-2014 01:16 PM
Dec-27-2014 12:40 PM
Dec-27-2014 08:45 AM
