Our custom true flatbed truck camper build thread
Jfet
Ok, I am going to collect random thoughts and progress pictures and put them here in a thread.
Goal: Construct a true flatbed camper with cabover, no slideouts but full 8 foot floor width inside. This will mount on a 2006 Isuzu NRR truck with a GVWR of 19,500 pounds and a current dry weight of 8700 pounds. The truck has a 20 foot flatbed that is 8 feet wide. The camper will take up 11 feet of the flatbed and the remaining area will be home to a future garage for our toys. We will install a hitch so we can pull our 17 foot Montgomery sailboat (trailer + boat is about 2200 pounds). The camper and garage will be removeable so the flatbed can be used for other purposes, or in case the truck needs extensive shop repairs down the road. Or if we are in Alaska and want to go pick up 3 cords of firewood or something 🙂
Here is a picture of the truck with some important dimensions:
518 REPLIES 518
Jfet
snowdance wrote:
You might also take a close look at a Newer Lazy Daze Class C. Roof made with things you know how to work.. Cost??
I looked on the site and LazyDaze seems to be using a one piece aluminum roof that is then painted. We had considered this as an option but I was not sure how easy it would be to obtain a continuous piece of aluminum sheet that is 8'6" wide and 21 feet long. The only thing I could find was really thin (0.024 or something). Perhaps I could find out the thickness of roof LazyDaze uses.
I am also unsure what to do with the edges of the aluminum especially in the corners and around the curve. It looks like LazyDaze uses some very large trim...not sure where we would obtain something similar.
snowdance
Snowdance
We spent most of our money traveling... Just wasted the rest..
Chevy 7.4 Vortex
2000 Jamboree 23b Rear Kitchen
http://www.flickr.com/photos/snowdance38
camperpaul
The edges of the fabric will 'bunch-up' on the curve.
You can alleviate this by cutting "V" notches in the fabric.
Take apart a brown paper grocery bag and use it to make a template for making the notches. You'll have to experiment a little to get the notches in the right places and at the right angle.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
Jfet
Problem with our roof idea. The Rhino Eco coat is just too expensive to be a viable solution ($3500 to $4000 and the installer is a 5 hour drive).
So now we are back to square one on our roof. The roof is made of 1/2 inch thick marine plywood over our steel frame, held on with Sikaflex 252 and countersunk sheet metal type screws. We have zero openings in the roof. I have made and installed 3/8" captive nut mounting holes on the sides of the RV in three places per side (two nuts per place) to attach a future roof rail system for solar panels without having to drill into the roof. These are drilled through the 1x2 steel frame on the side near the roof.
Ok. Fall back plan? Dicor BriteTEK Roof Membrane? It comes in 9'6" x 25 foot rolls with an installation kit. We would need to use strips on the sides to hold down the edges of the fabric. I am unsure how it would look on the edges on the front curved section.
Jfet
Thanks Nick. I am well familiar with the led strip lighting you can cut, as I used a roll of it to prototype some modular panels. I eventually designed and hand soldered (a pain!) several of these boards using the same 5050 smt leds (my wife wrote all of the microcontroller code). This is a short video of those boards 🙂
http://www.youtube.com/watch?v=P8oh7jHdjBc&feature=youtu.be
One of the main problems with led lighting is heat sinking. Some of the RV modules do not handle heatsinking at all..they just glob a few dozen leds on a terminal and call it a light. This Sylvania fixture has a nice amount of heat sink, which means the leds will last longer than the camper.
I will give you a call if I see some things we need at your store.
h2o4unow
I work at a hardware supply store that sells 12v led lighting. I would love to help you out with any lighting needs you may have. We have LED strip lighting that has a peel-and-stick 3M backing that can be cut every 3", 1.5 and 3w LED puck lights and all sorts of strip lighting that all runs off of a 12v transformer. So long as you keep the polarity in check, I have great luck with all of this stuff in auto applications.
If you need info or pricing, feel free to drop me an email or we can chat on the phone. I've really enjoyed following your project and would love to be able to return the favor.
Check out our website and let me know if there is anything I can help you with. www.thehardwarehut.com
Nick
nick@spokane-hardware.com
Jfet
We have not been happy with the selection of 12V RV led lighting (or those in the marine selection). The home improvement environment however has a nice selection of relatively inexpensive led fixtures. Recently at Lowes we decided to hack a AC ceiling unit made by Sylvania. This is a 900 lumen surface mount light that draws 13 watts and is equivalent to a 75 watt halogen (or this is what the box says at least).
I knew these units really run on DC but I didn't know how many elements they had connected in series inside the bulb. I figured it would be around 9 to 12 which would put it well above the 12VDC available in a truck camper electrical system. After taking off the cover of the small AC to DC module mounted with 2 screws to the back of the light housing, I first measured the voltage going to the led string from the power module. This turned out to be 42VDC. This means the 9 to 12 led elements in series was a good guess. Note that it could actually be constructed of two paralleled series strings of leds. Even though externally there are only two wires, paralleling long series strings of leds is somewhat ok in practice as they tend to self balance a little bit. Paralleling just two leds without current limiting devices would eventually leave you with one or zero working leds. 🙂
Anyway. I took some measurements at a few levels of current and found that the light just barely comes on, drawing 1mA at 32.8VDC. At 40VDC and 150mA (6 watts input) it was as bright as any interior rv or boat led light I have ever seen. At the rated 42VDC and 221mA draw, it was a small sun (call NIF and tell them we can now use those lasers for something else).
Note that I am seeing 221mA at 42VDC which would only be 9.3 watts of power input to the LED elements. Either Sylvania used a not very efficient AC to DC converter (9.3/13 = 71.5%), the 13 watt usage rating has some fudge factor in it, or the leds will have a slightly higher drop as they heat up, causing the power consumption to go up a bit. This last is probably likely and I will do a longer test eventually to confirm that.
Ok, so now we need a way to provide a constant current in the range of 150mA to 220mA with a voltage allowance of at least 42VDC, all from our 12V battery system. At first I thought building my own from scratch as there are plenty of reference designs from the IC manufacturers. A little more searching though and I have come across what might be just the ticket. This is a little module made by LEDdynamics called the LuxDrive A011 FlexBlock. It takes an input voltage of 10 to 32VDC (12V RV battery, check!) and provides an adjustable constant current output capable of driving a series string of LEDS with a total drop of up to 48VDC (needed at least 42VDC, check!) The price isn't too bad at $18 since you are getting an adjustable current source which will allow you to set the brightness and power consumption of your fixture. The Sylvania LED fixture itself was $36 at Lowes.
One other thing I like about this particular fixture is the base and bezel are all one piece of metal, providing a decent heat sink for the LEDS. With the FlexBlock boost converter operating at 90% efficiency and setting the current to 150mA, you would only have a couple watts of heat dissipated over a fairly large surface area of metal...should last forever.
Here are some pics of the back of the unit and a shot of it running at 1mA and 220mA:
recycler
thorsmitersaw wrote:
where do you look for them? I cant find any on craigslist that are in 4 wheel drive. Are there any with crew cabs
try looking in your local commercial truck trader advertisment paper your more likely to find one there
1999 F550 truck conversion
RobertRyan
Jfet wrote:
The 5.2 liter in the Isuzu NRR has quite a bit more power/torque:
Isuzu turbocharged intercooled diesel
5.2 L (317 in.3)
215 HP @ 2,500 rpm
452 lbs./ft. @ 1,850 rpm
Yes I know. Much more effective than tbe smaller 3 Litre Fuso.Isuzu has a "mini truck" as well.
Jfet
RobertRyan wrote:
Rbertalotto wrote:
Model 4P10(T5)
Type DOHC, 4-cylinder, 4-stroke cycle, water-cooled, turbocharged, intercooled diesel with 4 valves per cylinder
Displacement 183 cu. in (3.0 L)
Max. output (SAE, gross) 161 hp @ 3,400 rpm
Max. torque (SAE, gross) 295 lb.-ft. @ 1,300 rpm
Underpowered an understatement!! No the 3 Litre diesel is under an official truck rating for the Fuso here. OK as a small delivery vehicle. European Cab chassis variants of Vans are vastly better.
5.2 L (317 in.3)
215 HP @ 2,500 rpm
RobertRyan
Rbertalotto wrote:
Model 4P10(T5)
RobertRyan
jroddick wrote:
You're in the right location, most of them are in the NE. They're pretty rare out here in the west. Mitsubishi doesn't import the crew cab version in 4WD but they are a common sight in Australia
Pretty well everywhere here. Isuzu/Hino and Fuso in that order produce them in a Light Truck configurations(Like in the photo}. You have nearly as many as Medium Duty truck configuation as well, like your F650/F750 or Freightliner.
Jfet
I have been looking around at good inverter/charger solutions and I like the looks of the Magnum Energy MSH-M 3000 watt inverter with load sharing. It syncs to whatever other AC source you have available and will parallel share the load at the transfer switch. In our case the Honda 2000 watt generator plus this inverter would theoretically give you 5000 watts. I can't quite think yet of when I would need 5000 watts in a truck camper but hey, why not? Maybe running the MIG welder, coffee maker, hair dryer and A/C at the same time?
Magnum seems to be a top tier company and they are local to us in Washington. The only slight problem is the MSH-M in the 3000 watt 12V input version is still a few months out from production.
http://www.magnumenergy.com/Literature/Manuals/Inverters/64-0058%20Rev%20A%20(MSH-M%20Series)_Web.pd...
sabconsulting
where do you look for them? I cant find any on craigslist that are in 4 wheel drive. Are there any with crew cabs?
The expo in Flagstaff would have been a great place to look for them in person (there were a bunch of them there and all sorts of things were for sale.) I'd also start following the expeditionportal forum in their for-sale sections. People there are pretty hawk-eyed for chassis like these. They found the posting I put up for Don's old Dodge/Outfitter combo within 8 hours of my putting it up on CL and before I got a chance to post it on the portal myself.
If I had to upgrade my truck that would be pretty high on my list 🙂
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'98 Jeep TJ 4.0
'15 Ford Fiesta ST
'09 Fiat Panda 1.2
jroddick
You're in the right location, most of them are in the NE. They're pretty rare out here in the west. Mitsubishi doesn't import the crew cab version in 4WD but they are a common sight in Australia :
Jeffrey
" If you don't think too good..... don't think too much"
