Tailgate for a truck camper
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
โApr-22-2022 12:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-21-2022 03:08 PM
Tail gate on and off every time to use the truck That tail gate is getting heavier as I get older
Even if the camper fits in, the tailgate can get in the way of the camper steps
The OP will find out if he can get the crank in to lower the spare tire OOPs ?
It only takes a few times to remember to swap the licence plate to the camper Before loading it onto the truck. ๐
on Ford E350-460-7.5 Gas EFI
Photo in Profile
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-17-2022 07:59 AM
Grit dog wrote:
Yeah, I knew what you meant, but I don't buy the not able to haul weight thing. Although, I believe you qualified it as not "rated" to carry weight, which may be technically correct.
The tailgate itself can be built like a brick house, but it's still held up by two spindly cables, the subject of a pretty well known GM recall at one time. Funny it does not appear that GM or anyone else learned their lessons, because they still use spindly little cables to hold up the tailgate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-17-2022 07:39 AM
s1214 wrote:ThomasELee wrote:If you are looking at 'truck tents', no. Most truck campers you do.
Do you have to remove the tailgate for a truck camper?
That dude was a 1 hit wonder. He gone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-17-2022 06:43 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-16-2022 11:04 AM
https://www.hostcampers.com/wp-content/uploads/2019/07/0020-3.jpg
it looks like the tailgate straps would be in the way when the tailgate is in place and open. I am also not sure if nothing under the rear of the camper extends below the truck bed level.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-16-2022 10:44 AM
Iโd remove it because you know that will work. And then re-assess once you have the truck and camper together.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โMay-16-2022 10:41 AM
2023 Host Everest
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โApr-25-2022 07:45 AM
deltabravo wrote:Grit dog wrote:
Iโll have to call shenanigans on this.
There was a typo in my post. I fixed it.
Yep, I have seen bent tailgates from long term usage of hauling stuff that rests on the tailgate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โApr-25-2022 06:11 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โApr-25-2022 05:31 AM
burningman wrote:
The only REAL issue is the cables or straps that hold the gate when itโs open usually interfere with the camper because it widens out right behind the truck bed, and/or the camper has holding tanks below the rear overhang area, or a black tank dump port.
As for the notion that the gate will be damaged because it isnโt designed to support much weight, how much weight is really on it if you can remove the tailgate and carry the camper without it?!!
I agree, I don't think the weight would be a problem with it distributed across the truck bed. It's not like it's all sitting directly on the truck tailgate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โApr-24-2022 03:00 PM
specta wrote:Grit dog wrote:
And to my point, newer trucks tailgates are significantly thicker, heavier and better built than the 70s-80s models of trucks.
Back in the 70s Ford used to advertise that their tailgates could support up to 2000 lbs.
I'd be willing to bet that the tailgate on my 1976 F-250 would support more weight than the tailgate on my 2011 Chevy.
Well, I donโt remember car adds from when I was in kindergarten, but have no doubt that โoldโ tailgates are also strong. I was replying to whoever said newer tailgates werenโt designed to carry loads.
Sure, the GM Swiss army tailgate and the ford models with the built in Grampa handrail may not work due to their complexity, but most of the rest of this conversation is meaningless speculation. Generally fueled by those who donโt know the difference between a tailgate and a split tail! Lol
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โApr-24-2022 10:26 AM
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โApr-24-2022 09:28 AM
1996 Jayco 376FB Eagle Series TT
1997 Jayco 246FB Eagle Series TT
1976 Ford F-250 4wd Mercury Marauder 410 - 4V
Regular cabs. The best looking trucks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โApr-24-2022 09:10 AM
stevenal wrote:
My camper doesn't extend down, but it does extend out. The tailgate cables would interfere. If your camper has taillights and your tailgate has cables, you'll need to remove the tailgate.
You forgot the word โmaybeโ. Do yโall not realize there are literally hundreds of different truck and camper combos and what works or doesnโt for you is not necessarily indicative of someone elseโs setup?
I mean, the tailgate cable was in the way on mine, after it was t, because I built a genny compartment.
So should I recommend it wonโt work to everyone?
