May-20-2021 11:00 AM
May-30-2021 08:52 AM
May-30-2021 08:04 AM
Geo*Boy wrote:Longshore wrote:
I have the short bed I guess I can find mud flaps and slide them under the mat front and back. I did notice a pretty good rock backwards when stopping, but the truck was real low on the back and I thought that was the cause.
If the gap is in the back, just place the flaps in the back to compensate for the crown.
May-29-2021 05:25 AM
May-28-2021 10:15 PM
May-28-2021 03:21 PM
Longshore wrote:
I checked my 2015 GMC 3500 and yup a four foot level rocks about 1/8" centered over the drive axle. You can't really see it till you get down and look straight up the floor of the bed. But with a one inch stall mat would this be an issue?
May-28-2021 02:32 PM
May-28-2021 07:39 AM
Slymer wrote:
Ours always looked tilted too & it made no sense. Finally figured out something. Take a 5 ft board & put it across both bedrails, just behind the back window. Now take a measurement from the bottom of that board to the truck bed. Now take that board and move it back just forward of the tailgate & take that measurement again. On our 2011 F350 there was almost an inch difference if I remember rightly. Basically a manufactured optical illusion. No idea why, so I just got used to it.
May-27-2021 03:01 PM
May-25-2021 08:32 AM
Supercharged111 wrote:
I don't think the 97 bed is crowned, I'd have to take a straight edge to it to be sure as was mentioned. I also used my planer to taper the edge. If I'm only using the 1 piece, I'm thinking the shorter one will be better. I thought more people had done the shimming, I do like the stepped semi mudflap idea though. I'll have to check again, but I don't think the rails are tapered either.
May-25-2021 05:27 AM
May-24-2021 06:10 PM
May-22-2021 07:42 AM
May-21-2021 09:50 AM
May-21-2021 06:26 AM
