water pump
langleyger
Can't locate my water pump, on my 2013 89RB Adventurer truck camper.
10 REPLIES 10
StirCrazy
Navigator
Navigator
Lazz101 wrote:
My battery box is on the outside. The step is secured down, I felt around for screws and canโ€™t find any. It seems to be stapled down. But I donโ€™t want to reef on it any harder then I already have if it screws or something and canโ€™t find them.
looks like they may have moved a few things around over the years. Did you look in the basement and under the bathroom sink? Generally, they are very close to the freshwater tank.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
MORSNOW
Navigator II
Navigator II
Try taking a magnet over the top and find the hidden screws in the carpet.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD 7,220# Truck/10,400# Camper Fully Loaded
Lazz101
Oregun
StirCrazy wrote:
Lazz101 wrote:
How do you get the step off above the water pump to access it on an adventure 910?
I think the 910 has the box of the battery compartment under the step, doesn't it?
No not mine. Battery compartment is outside in the wall.
Oregun
Put the slide all the way out and lift up the step at the bathroom side.
StirCrazy
Navigator
Navigator
2016 Cougar 330RBK
Lazz101
Oregun
I have a 2013 910FBS Adventurer camper and the pump is up front under the step for the bed just like ssthrd stated above. The cover removes for access.
deltabravo
Turn it on and listen. Use your ears to follow the sound to find it.
ssthrd
Should be near the tank. My guess is that it's up front in the compartment under the step up to the bunk.
Have you tried turning the tap on and listening for it?
Or maybe you are asking because it is not working........
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
