โJan-12-2014 01:41 PM
โFeb-05-2014 03:24 AM
anutami wrote:
Northwood agreed to reinforce the tie down anchors on a new custom build 2014 wolf creek 850 and I pulled the trigger.
โFeb-04-2014 09:22 PM
โJan-16-2014 10:21 AM
โJan-16-2014 06:08 AM
BradW wrote:Redsky wrote:
I did a rough calculation of the wind force side load on my 845 camper and with a 50 MPH gust the force is about 844 lbs., which is not all that much and countered largely by the weight of the camper. But with a 70 MPH gust the side load nearly doubles to 1660 lbs. of force. It's the gusts that will get you.
The problem is that all that force needs to be resisted by the two windward hold downs on the camper. The turnbuckles are designed to provide 300 lbs. of holding force or 600 lbs. per side so even a 45 MPH gust could overwhelm them.
Just so no one is confused, 1,660 lbs side force does NOT translate into 1,660 lbs of force on the tie downs. The force on the tie downs would be MUCH less. I assume your calcs are based on the wind being exactly perpendicular to the camper side? What are the odds of that?
Also, if there had been 70 mph wind gusts, you would have seen a LOT more dust blowing around in those photos.
Brad
โJan-16-2014 06:02 AM
โJan-16-2014 05:56 AM
โJan-16-2014 03:15 AM
โJan-15-2014 10:30 PM
sleepy wrote:
bcbigfoot
the Lance is designed for a 6 point tiedown...
2 of the strut dampers provide the forward attachments
2 of the Happijacs provide the center attachments
2 of the happijacs provides the spring loaded rear attachments on the rear bumper
I'll take 6 point attachments over 4 point attachments any time
sleepy
โJan-15-2014 09:46 PM
sleepy wrote:
bcbigfoot
sleepy
โJan-15-2014 09:26 PM
sleepy wrote:12V Cummins wrote:
I don't think cab over struts would have done anything in this circumstance. If a camper has a good COG it does not need struts and you do not get "porporsing". If i recall the cog of a 850 is pretty good especially on a long bed.
These are actually oil filled piston dampers (strutts are rigid)
Have you ever driven a truck and Lance Truck Camper with the dampers?
โJan-15-2014 08:06 PM
โJan-15-2014 07:50 PM
mike mck wrote:
anutami
Wow as I look at the photos I am trying to picture what kind of a wind gust would push a 4000 lb camper over or thru a bed rail.
Tiedowns or not.
If you were in an off camber situation going up that berm. I could understand the forces required to create that situation.
As to camper tiedowns and construction the question becomes design intent. I do use torklift tiedowns and have no expectation they will hold the camper weight while of camber enough for the camper to roll over the bed. My expectation is it will hold the camper in place from sliding forward or back in the bed.
It appears the wind gust was enough overcome the ability of any tiedown system or rig was so far off camber the weight of the camper overcame the design intent of the tie down area of the camper.
just my 2 cents
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โJan-15-2014 07:31 PM
โJan-15-2014 06:34 PM
sleepy wrote:
bcbigfoot
sleepy
โJan-15-2014 05:27 PM
