Hiway 9 South of Lake Placid NY - Clearance Issue?
Teamfour
One of my online maps shows a low clearance warning for NY Highway 9, south of Lake Placid, right after exiting the interstate. Can any one shed some light on this warning? Is the underpass RV friendly?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 locker, 3,295 Payload
2014 Salem Hemisphere 282RK 7.8k lbs loaded, Equal-i-zer WDH
3 REPLIES 3
haddy1
Sometimes, the clearance "issue" can be the clearance on the far right side of an oval shaped tunnel or bridge and you will be ok if you keep to the left. The local signs are probably a better guide than a map or gps.
2019 Tiffin Phaeton 37BH
2018 Grand Cherokee Toad
lbrjet
According to my truckers atlas the bridge under I87 is low clearance at 12' 9''. Doesn't list anything else right around there.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
rwbradley
I just drove that run a week ago with a 21' hybrid with 10' height/ 8' width. I do not recall any height clearance issues, however they are doing bridgework on 9N in Au Sable Forks. The bridge is down to 1 lane (alternating traffic). It is very narrow and I could see it being an issue for a big 5th Wheel especially on the side that has the T intersection. I found it quite tight with my HTT.
I do faintly recall seeing signs about that, but I think they are referring to width clearance, not height.
Rob
rvtechwithrvrob.com
