Nov-02-2016 06:40 AM
Nov-22-2016 04:29 AM
Nov-22-2016 04:14 AM
Nov-21-2016 10:28 PM
Nov-21-2016 02:37 PM
shum02 wrote:
Too funny!
From the MTO's FAQ's section
Q15: Is my pickup truck a commercial motor vehicle and does it need a CVOR?
The Highway Traffic Act considers all pickup trucks to be commercial motor vehicles.....
BTW my F350 with me and a full load of fuel is dead on at 8000lbs or 3600kgs just like the door jam says.
I don't care, it's personal use and I'll load her up to the limit of 11000kgs and feel the exact way.
Nov-21-2016 02:18 PM
Nov-21-2016 11:37 AM
JaxDad wrote:shum02 wrote:JaxDad wrote:
Having not just a personal truck in this category, an F-350 DRW 4x4, but a small fleet at work, we run into this ALL the time.
I have NO fleet, am not part of a fleet, no yellow sticker and pulling over a F350 with a RGVW of 4000kgs and weighing me will show anyone I'm under.
In these "spot checks" I only see guys with trailers and loads of gear in their trucks using "personal" trucks as work trucks. If you do that you are COMMERCIAL. Had a neighbor get nicked for that even after I warned him about it with his Ram 1500 using it for a driveway sealing business - got nicked!
I see this confusion all the time, there is NO such thing as a "personal" pickup truck in Ontario. If you have black & white plates you have a COMMERCIAL vehicle, period.
Compare the ownerships of a car and your pickup, you will see at the very top the term "COM - FIT" (commercial) on your truck and "PAS - FIT" (passenger) on the car ownership.
For an RV there is however several exemptions from some commercial vehicle requirements. But as a commercial vehicle you can be stopped at anytime for no particular reason in order to 'inspect' the truck.
BTW, the physical weight or registered weight means nothing, if the manufacturers GVWR of the truck and any non-exempt (RV) trailer exceed 4,500 kg, you are required to have a comm. safety inspection on both.
Considering the lightest F-350 GVWR is 4,491 kg you are at, if not very likely already over that limit. If you so much as hook up to little 4'' X 8' box trailer you are risking some hefty fines.
Nov-21-2016 05:09 AM
gitane59 wrote:
What really rots my socks with fiver pickup truck licensing is the free pass motorhome owners and drivers get.
Also if ignorance is no longer bliss than the un-civil servants in the MTO offices need to go back to school to learn the laws and there interpretations. Had a license office agent rudely show me the door when I insisted I did not need a CVOR and I wanted the exemption document. Agent had no idea what I was talking about at all.
Nov-21-2016 05:02 AM
Nov-21-2016 03:33 AM
Nov-21-2016 03:19 AM
Nov-20-2016 06:36 PM
Nov-17-2016 03:50 PM
Nov-17-2016 01:51 PM
portliz wrote:
Your friend is correct. You must know the weight of your truck with 5th wheel attached and the weight of rig with 5th wheel attached. This determines what RGW you put on your ownership. Check with license office. They are stopping rigs in Ontario and pulling in to be weighed. You can be fined. Yes it costs more to be legit. We just went thru this. If you have a lighter rig you may pay less.
Nov-07-2016 05:27 AM
shum02 wrote:miatared wrote:CoMoCo wrote:
Here is some current info - look at questions 15 and 16 in particular.
Commercial vehicle FAQ
Many thanks, I now Understand.
I will state that NO ONE uses this. Most 1/2 ton trucks towing some of the trailers I see are WAY over that rating. Register the truck for the least amount you can. The MTO cares less about pickups used for PERSONAL transportation and towing.
Nov-04-2016 04:31 AM
