Campground near Boston/Salem
Hector_Bravo
Good Evening,
I’m looking for a nice full-hookup Campground with decent access to Boston and Salem. (Normandy Farms does not currently have availability for the dates we need.)
Any suggestions?
Thanks in advance.
The Bravos
2013 Jay Flight 26 RLS
2014 Ford F 250 Super Duty 6.2
7 REPLIES 7
Hector_Bravo
Minuteman worked well for our needs so I made reservations. After that it is off to Atlantic Oaks on the Cape. This trip was delayed from last year so I am very excited to have it on the calendar.
Thanks for the help!
The Bravos
fwed
Minuteman is in Littleton -- I stand corrected. That's what I get for depending on my memory. It's still a good bit closer to Salem than Plymouth or Normandy Farms.
There are others much closer, but with their own set of problems. Beacch Rose in Salisbury is nice, but hard to jack-knife anything bigger than a PUP in there. Cape Ann CG in Gloucester is okay. We just prefer Minuteman for it's proximity to many areas.
fwed.
Hector_Bravo
Thank you, all. I am not eligible for Hanscom and I will checkout the other suggestions.
Living outside of NYC I appreciate the advantage of mass transit. Thanks for the tip.
Thank you all so much.
The Bravos
jplante4
Winter Island park is in Salem. Got a 7.5 on RV Park Reviews. Minuteman is an hour at least from Salem.
BTW Minuteman is in Littleton, not Lincoln.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
fwed
Minuteman CG in Lincoln -- NW of Boston. Near enough to I-495 for easy access, bur far enough to be quiet. Lexington and Concord very near.
fwed.
jfkmk
We stayed at Pinewood Lodge in Plymouth. It's a little south but an easy commute to Salem and Boston. Use mass transit to get into Boston. You won't regret it!
Second_Chance
If you're eligible, we've stayed at the Hanscom AFB FamCamp north of the city. It served us well for day-tripping and seeing the area (although Salem was a bit of a disappointment).
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
