Electric only sites
NHDad
We will be doing our first camping at electric only sites at Ludington SP and Indiana Dunes SP next month. Will there typically be a water fill station I can bring the trailer to for freshwater fill up after I check in?
28 REPLIES 28
wbwood
Go to Walmart and get you a few 5-6 gsllon water jugs.
Brian
2013 Thor Chateau 31L
michigansandzil
We stayed at Ludington two years ago. You can fill at the dump station but you can't fill from the water spigot inside the campground itself. A hose just won't fit. Never used a water thief but after a quick glance, it doesn't appear that it will fit onto the spigots at Ludington. I think the spigot is too wide to accommodate that.
To refill our fresh water, we use a large soft tank that can go onto the top of your tow vehicle. We fill that with clean water, then let it gravity feed into the TT. Works great for the MI state parks, b/c very very few have water on site.
2017 Coachmen Catalina 323 BHDSCK
2018 Ford F150 FX4
3 growing kids and 1 big dog
JJnLilly
Most hydrants now have a threaded anti-siphon end on them to prevent back flow. I still carry a 'cheater' but have not had the need to use it inyears.
2007 Ram 2500 QC CTD
2020 Passport GT 2210
GordonThree
PegLW wrote:
We've stayed at Ludington SP. There is a place to fill your water tank in the same parking area as the check-in office. We drove right past it,as it's on the left immediately after entering the parking area, and had to circle around after checking in but it wasn't a huge problem.
That station has been removed.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
jaycocamprs
Indiana Dunes SP has a water fill right after the check in station.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
stickdog
I usually fill my fresh water tank when pulling in, most public cg's have fresh potable water tap near the dump station. We seldom stay more than three nights at electric only campgrounds but again many but not all have showers, if they do I use those DW refuses to public facilities.
We were forced to stay a week last winter at an electric only site I purchases a 6 gal fresh water container to replenish our fresh water. No need to carry 100 ft of hose.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
pipers_family
We were so surprised coming from Texas to find that so many midwest and northern state and corp parks did not have water at each site. We remember to look these days- not fun to set up completely and then have to haul water or unhook and go fill tanks.
PegLW
Dave and Peggy
2012 Open Range 345RLS
2015 Ford F350 Platinum 6.7L turbo
GordonThree
coolmom42 wrote:
sch911 wrote:
Michigan state parks have potable water spigots at the dumpsite island. The water spigots throughout the campground are specifically designed to fill pots and jugs only, even the water thief won't work.
How are they made that a water thief won't work? Not arguing with you, just curious.
The Michigan State parks I've been to have gone to a few different spigot types to thwart hosers.
First is the steeply tapered smooth spigot. This spigot is very wide at the top and tapers down quickly, so even a hose clamped water weasel will slide off with the slightest back pressure
Second I've seen is the trough style spigot. Kinda like a rectangular bath tub faucet upside down, water flows into this spigot from the bottom and flows down a trough. You'd need a water weasel 6 inches across to mount this faucet, and I don't know how you'd seal around the open trough part.
GordonThree
Ludington SP:
You can fill up your trailer at the contact station, about a mile south of the park. They have threaded hoses so you can attach a filter if desired. This is also where you dump after your park visit.
Inside the park, there are lots of handicap accessible water spigots. They have a large pressure plate you push and hold to dispense water out of the un-threaded nozzle, which was too big / smooth for a my water weasel to fit on - it would just blast off with the pressure. Best to bring a funnel if you're filling jugs.
2gypsies1
In Michigan State Parks and most state parks and national parks you will find the tank water fill in a separate area at the dump station. Do not use the water hose at the dump itself. Be sure you use the potable water and it's marked as such.
If you ever encounter parks without a dump station then that's where you will need to use a water thief or fill containers from the scattered faucets in the park.
Full-Timed for 16 Years
.... Back in S&B Again
Mfan
Water thief won't work at michigan state parks? Shoot, mine's defective then. I use it all the time
2oldman
The one I used was about here: 41.658358, -87.054121. Threaded connection, all the water you need.
NHDad
Thank you!
