Must Have Boondocking Items?
Mello_Mike
Let's have a little fun. What do you consider to be "must have" items when you go boondocking?
I'll start:
1. Two AGM 6v or Group 27 12v batteries
2. Solar power (100 watts)
3. Propane (2x5 gal tanks)
4. Seven gallon portable water tank
5. First Aid Kit
6. Water Purification Kit
7. Saw Zaw (for cutting firewood)
8. Firestarter
9. Camera
10. Altimeter App
11. Dump Station Location App
12. GPS/Maps
13. GPS locator
2016 Northstar Laredo SC/240w Solar/2-6v Lifeline AGMs/Dometic CR110 DC Compressor Fridge
2013 Ram 3500 4x4/6.7L Cummins TD/3.42/Buckstop Bumper with Warn 16.5ti Winch/Big Wig Rear Sway Bar/Talons w/SS Fastguns
My Rig
1998 Jeep Wrangler
US Navy Ret.
199 REPLIES 199
Tvov
smkettner wrote:
LED lights really made a difference on my battery power.
I agree very much. We just use LED flashlights and camping lanterns. We are able to make our single 12v battery on our TT last a good 5 days+ by careful use. We use the camping lanterns in the TT.
When the LED flashlights first started coming out years ago, I was less than impressed. The last couple years it seems that the technology has "matured" enough that they are dependable, really bright, and seem to last forever. Most new LED flashlights we have had have failed from breakage (dropping, running over with a truck, etc) as opposed to running out of battery power. During hurricane Irene none of our LED flashlights ran out of battery power. I have no idea how long they last, but it seems like forever!
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
pnichols
I always like these type of discussions cuz I've spent a lifetime thinking about and getting ready to do boondock RV camping in retirement. Here's some of the actual "must haves" we take into account when boondock camping in our 24 foot Class C motorhome:
- We have a quiet 4KW built-in generator for battery charging, for A/C in hot weather, for the microwave, and for emergency heat in case of propane system failure ... fueled via the main 55 gallon chassis tank for long run times if required.
- We also carry a quiet protable generator as a backup to the built-in generator for battery charging and limited emergency heat in case of propane system failure. Fueled via it's built-in tank, plus a 2 gallon full safety rated steel portable gas tank carried in an external steel lined storage cabinet.
- We carry a 12 ton bottle jack with a double cylinder for extra high lift for changing our own tire if absolutely necessary.
- We have a rooftop cellular antenna with a send/receive boost amplifier for long range reach on our cell phones and Internet connection.
- We carry five step up leveling blocks for the worst case 3-point leveling situation of the four rear tires plus one front tire.
- We take a portable 12V refrigerator along for emergency use in case the main propane refrigerator should fail out in the middle of nowhere.
- We carry a set of crutches along in case someone should sprain an ankle.
- We carry a heating pad, a blood pressure monitor, and a large medical supply portable cabinet along in case of medical emergencies.
- We carry a plunger along in case of a clog in the kitchen sink or bath sink.
- We carry along a 110V AC full power tankless portable compressor that can fully inflate the motorhome's tires. The built-in generator easily powers it.
- We carry a full size shovel along.
- We bring hand held pruners along for camp sites with low hanging limbs.
- We carry spare fluids and spark plugs for both generators and the main chassis engine.
- We carry 100 feet of potable water hose.
- We carry 30 feet of sewer line.
- we carry 80 feet of cabling for shore power.
- We carry two 25 foot drop-cord lights.
- We have over-size tires on the motorhome for increased ground clearance.
- We carry a portable heater that either generator can power for emergency heat in case of propane system or propane furnace failure.
- We carry 15 feet of high strength chain with hooks on each end ... capable of towing our motorhome, or pulling it out of a stuck spot or the ditch.
- We carry a backup battery charger in case the built-in converter should fail.
- We carry a roll of 4" Eternabond, chaulking, and a chaulking gun for emergency repair of any leaks in the roof, walls, or windows.
- We carry a bucket for emergency transfer of water from a full grey tank into a non-full black tank.
- We carry another potable water bucket and funnel for emergency manual filling of the main freshwater tank from water sources without hose fittings. I guess we could fill it this way from a stream too, if we wanted to trust the water in the steam.
- We bring along an inter-connection valve for emergency merging of the grey and black tank contents.
- The same valve from above can be used as an emergency replacement valve for the main grey or black tank valves.
- We bring along a high volume portable 12V fan, plus a 25 foot extension cord for it, to use for outside cooling/fly blowing at the picnic table or to use inside in case of A/C failure in hot weather.
- We bring along various types of flashlights and portable lights, as many of them LED as possible.
- We bring along extra batteries for everything ... lithium batteries, if available in the required size, for long life.
- We bring along a full size outside table for campsites without a table.
- We bring along 2 full size outside lounge chairs - one medium size and one large size.
- We bring along 4 regular outside chairs.
- We bring along 3 chair side-tables.
- We bring along fishing gear, just in case.
- We bring along ultra-detailed Landmark map books of every area we travel in, if available for the area.
- We bring along a Garmin navigator loaded with huge amonts of 3rd party POI data well beyond what normally comes into the unit during the factory quarterly updates. This 3rd party data also includes low height overpasses for the entire U.S. - with audio warning capability any distance ahead you want to set the warning for.
and ... last but not least ...
- We bring along two different mosquito repellant systems for outside use when sitting around the campfire!
2005 E450 Itasca 24V Class C
time2roll
All I need is 1000w gen to power the 35a three stage converter.
Two inverters take care of the 120v power as needed for other stuff.
LenSatic
alpenliter wrote:
TMBLSN wrote:
LenSatic wrote:
We can also carry up to 42 gals. of water in addition to the 31 gals. on-board.
LS
What do you use to carry that water? I've been looking for a good solution for transporting additional water.
Thanks.
You could order one of these!
True. But one leak in 6 vs. one leak in one...;) Plus, 360 lbs on the roof when we are negotiating rugged back country roads ain't too wise.
dave54 wrote:
I also question a 7 gallon water tank. That is around 60 pounds I would have to lift and pour into the tank. I can do it, but I would be seriously grumbling about it.
I'm 61. When I went to Basic Training at Fort Polk, LA, in '67, SSG Porter, our PT Instructor, told us that, "Getting in shape is hard. Staying in shape is easy." I'm still in shape! ๐Ÿ˜‰
LS
ETA: I took the OPs reference to survival seriously. Was I mistaken? I take survival VERY seriously.
2008 Casita SD 17
2006 Chevy Tahoe LT 4x4
2009 Akita Inu
1956 Wife
1950 LenSatic
rfryer
A 45 ACP, water, food, a camera, books, one charged battery, a full propane tank, maps and a compass. Oh, and the DW.:D
Alpenliter
TMBLSN wrote:
LS
Thanks.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
dave54
Agree a solar array is not essential. Neither is a generator, depending on how long you are out, your battery setup, and how power-conscious you are. My longest without needing to recharge has been 5 days.
An air card? If you have cell or wifi service you are not truly boondocking. ๐Ÿ˜‰
I also question a 7 gallon water tank. That is around 60 pounds I would have to lift and pour into the tank. I can do it, but I would be seriously grumbling about it. You can have a portable pump, but then there is no need to limit your refill jug to 7 gallons.
One thing not mentioned is a set of 7.5 minute topo maps of the area. Downloaded off the internet while in the last wifi hot spot before heading into the hills. Or orthophoto quads.
The arsenal is also subjective. We boondock in some pretty remote areas too. So remote no one ever finds us. No miscreant intent on evildoing is going to cruise the backcountry twotracks looking for easy prey. We also are armed, but for 4 legged pests.
So many campsites, so little time...
Mello_Mike
s1214 wrote:
Peace, quiet, solitude.
Isn't that why we boondock in the first place? ๐Ÿ™‚
My Rig
1998 Jeep Wrangler
US Navy Ret.
s1214
Jayco-noslide
Found some round battery lights about 4 or 5 inches across at Home Depot or Lowes that take 4 AA batteries. Real nice to put on the wall in the bathroom or over the couch so as to have a little light without using up the trailer battery. Quite inexpensive. The light is not bright but not bad especially for the short, summer evenings.
Jayco-noslide
jauguston
Mike,
I was using the OP's description of "Essential" and the statement that a generator would be one essential item. If you have a generator that makes a 100w solar panel nice but not essential in my opinion.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Mello_Mike
jauguston wrote:
I would not consider a 100w solar panel essential. It is not going to put out enough to eliminate the need for the generator so what is the purpose? It would be fine for storage where you have no access to shore power but it is not going to eliminate the generator so why bother.
Jim
It depends on what your needs are. A 12v system comprised of two 6v golf cart batteries, a single 120 watt solar panel, and MPPT solar charger is more than enough for my needs. Power for lights, 12v water pump, fans, TV/RADIO, and DVD player is all I really need. I only use the generator to fire up the A/C and microwave and maybe recharge the batteries on a cloudy day.
Now if I had a 40 ft motorhome, like you, it would probably be different. ๐Ÿ™‚
My Rig
1998 Jeep Wrangler
US Navy Ret.
profdant139
Actually, instead of a chainsaw, I bring a small bow-saw. Never runs out of gas, no noise, easy to start! And we actually used it this last summer -- in the Jackson Demonstration State Forest near Ft. Bragg, CA, they allowed us to cut downed wood for firewood. Good exercise, too!
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
rockhillmanor
pondputz wrote:
I never leave home without:
400 watts solar
wind charger
solar lights
whiskey
steaks
BBQ
memory foam mattress
chainsaw
aircard - computer - camera
comfortable chairsPutz
Ok, I'll bite. What's the chainsaw for?:h
2oldman
A couple grenade launchers, a bazooka, and an air card.
