โMay-12-2013 04:34 PM
โMay-24-2013 05:34 AM
โMay-24-2013 05:22 AM
rwj146 wrote:
Thanks Woodglue, I just watched the video. Very well done. I had to give up my TC due to health reasons, may have found the trailer I need (want). Thanks.
โMay-24-2013 05:02 AM
โMay-24-2013 03:03 AM
โMay-24-2013 12:03 AM
โMay-23-2013 01:54 PM
โMay-22-2013 10:58 PM
โMay-19-2013 07:10 PM
โMay-15-2013 02:10 PM
PUCampin wrote:
To the OP, if you are interested in a TT, a smaller single axle with a flip kit would be a place to start. There is a member profdant135 or something like that who tows a modified single axle fun finder behind a Toyota 4x4 and has managed to get to some very out of the way places.pnichols wrote:RWDIII wrote:
This is a pic of my rig at the Racetrack in Death Valley over 50 miles in 4wd round trip
A bit off topic ... but I'm curious. Could our small (24 foot) Class C E450 motorhome make it to the Racetrack in DV??
FWIW, I've traveled offroad in/out for about 50 miles of heavy washboard with our MH in the OR outback. And I've went about a mile on a 4X4 roadbed in DV (consisting of 3" to 4" size rocks) in DV with our MH and it's rear duals and 10-ply tires all around.
Why is 4X4 needed for the trip to the Racetrack ... is it more a matter of tough tires and careful negotiating around some large rocks ... or is the additional traction from 4X4 actually needed due to sand, steep slopes, etc..? Or, is what's mostly needed is the additional ground clearance that some 4X4 RVs have?
I wonder if anyone has ever went to (and returned from!) the Racetrack with an E350 or E450 Class C motorhome?
I apologize for the questions - but just curious, since you've been there. :h
In general, the road is high clearance 2WD and not particularly difficult. We used to go out there in our old VW bus, and some years ago my brother and I went out there in my 2WD open diff Ford Ranger with no issues. It is not so much a traction issue as it is a rough road with some ruts, rocks, and short hills / whoops and narrower sections. Without knowing your specific RV, if your RV is not extra wide, has good ground clearance with good approach and departure angles as well as good breakover angles (shorter wheelbase), and you are competant at driving and manuvering you might be able to do it. Most class Cs I know of do not have what I would call good approach, departure or breakover angles. If you do go, make sure tires and spare is good, have an extra can of fix-a-flat, an air compressor, and can change a tire by yourself. Drive gingerly and avoid the rocks as much as possible, and if a section looks questionable, don't. A tow out will be exceedingly expensive.
Actual road conditions can vary significantly depending on recent weather and if the road has been serviced. Check actual conditions at Furnace Creek, Stovepipe Wells, or Scotty's Castle before setting out. Plan on it being an all day trip.
โMay-15-2013 10:07 AM
โMay-15-2013 08:56 AM
โMay-15-2013 05:02 AM
โMay-14-2013 09:04 PM
โMay-14-2013 08:14 PM
