microwave replacement
pianotuna
Nomad III
Nomad III
Hi All,
My Dometic microwave turn table has died.
I do have a capable 3000 watt psw inverter.
What would you choose to replace it?
I'm tempted to just use it without the turntable.
I might gain a little storage by replacing it.
Regards, Don
3 REPLIES 3
wa8yxm
IAMICHABOD wrote:
You can replace that turn table motor fairly easy,I have done 3.
They have many replacements on Amazon
Dometic... I do not know about yours but Mine was made by LG (Lucky Goldstar) and I have not been all that Lucky with Goldstar products.. Long story omitted.. So far I've had just one that works. I avoid them.
Now the microwave.. The problem it had was the turntable motor. the plastic shaft was just flat too short. in addition the hole the 3 arm went through to engage the motor.. Too small.
The solution.. GE uses the same motor but it has a longer metal shaft.. So I replaced it.. And I enlarged the hole slightly.. Just enough the 3 arm could go through and turn freely. Worked for 16 years after that.
larry_cad
X2
Today is my personal best for most consecutive days alive.
Our Travel Blog
IAMICHABOD
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
