Recommend nice spot in Sourhern AZ?
Bill001
Other than Quartzite, any recommendations for a nice spot w outhouse near trails in east of Tuscan, Hows Nevada in the winter?
Thanks
B
13 REPLIES 13
cewillis
Or use GE as originally suggested --
"I suggest looking at the area in Goggle Earth. Camp sites are plainly visible."
Cal
garyhaupt
Bill001 wrote:
Does Black Jack have enough sunlight for solar, since it's in Pines and Junipers
B
Bill, if you jump into Google Maps, type in the name of the place then shift from map to sat view, you will be able to see all.
It's the boondockers pal.
https://www.google.ca/maps/place/Black+Jack+Group+Group+Campground/@33.056018,-109.0798933,127m/data...
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
Bill001
B
BeardownAZ
The Gila Box is nice for desertcamping. So is an area right across the NM line in AZ called BlackJack campground. It has outhouses. But its in ponderosa pines and junipers, if that matters. Both areas are about 1.5 to 2 hr drive east of Tucson.
EsoxLucius
Or Old Pueblo.
2013 LTV Unity MB Theater Seats
635 watts solar panels, 440 AH batteries, BlueSky Solar Boost 3024iL & IPN-Pro Remote, Magnum MS2000 & ME-RC50 remote
Koni Shocks F & R, Hellwig 7254, SumoSprings F & R
2012 Hyundai Accent SE, Blue Ox Aladdin/Patriot
azdryheat
Bill001 wrote:
Thanks! Coming out of NM, I'm surprised how much is closed and lacking signs in AZ
Will check out the Tuscan areas mentioned above; also thE Gil's Box
Thanks!
Bill
Bill, you'll fare better here if you refer to our city as Tucson. ๐Ÿ™‚
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
EsoxLucius
Patagonia, AZ
Portal, AZ
Look 'em up, lots of possibilities.
Currently at Sentinel Peak RV Park, Tucson, AZ
Mandalay_Parr
Might check out Parker and Lake Havasu City. Both on the Colorado river.
Why not pick a nice RV park with full hookups?
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
2gypsies1
If you want true boondocking (no outhouse, I don't believe) here is a place at Tucson and it's near the great hiking of Tucson Mountain Park.
http://wheelingit.us/2013/03/01/boondocking-site-review-snyder-hill-blm-tucson-az/
Full-Timed for 16 Years
.... Back in S&B Again
Bill001
Thanks!
Bill
2gypsies1
This is an absolute beautiful campground in Tucson with hiking trails surrounding it. Sorry... not outhouse... it has flushies. ๐Ÿ™‚
http://webcms.pima.gov/cms/one.aspx?pageId=1327
Tucson also has the Coronado Nat'l Forest campgrounds along the Catalina Highway but not sure if they would be open in winter.
http://www.fs.usda.gov/recarea/coronado/recreation/camping-cabins/recarea/?recid=74395&actid=29
Also, just south of Tucson are the Santa Rita Mountains and Coronado Nat'l Forest campground, Bog Springs - for small RVs. It gets occasional snow but will be cold.
https://www.arizonahighways.com/explore/camping/bog-springs-campground
Catalina State Park on the north side of Tucson has access to hiking trails as does Sabino Canyon day use facility.
In winter, desert hiking is the best and most of it will be in mountains but not high extremes for snow.
There's awesome hiking all around Tucson. Come and experience it!
I wouldn't even put Tucson in the same category of Quartzsite. It's not known for hiking.
Nevada is cold as is the higher mountain country of Arizona.
Tiger4x4RV
https://hikearizona.com/
Clickable map of regions, with hiking trip reports and photos from each.
https://www.visittucson.org/things-to-do/hiking
Hiking in and around Tucson
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
cewillis
How far east are you looking?
Gila Box
Couple of other pictures at the end of http://www.ctwillis.com/CamperTrips/E%20Az/index.html
Cal
