12V meter and receptacle
IBcarguy
I just installed a 12V lighter receptacle with a volt meter in my entertainment center. I wired it with a switch so the digital meter doesn't run constantly. It's wired so that when shore power is hooked up, I can monitor the inverter/charger rate to the batteries. When the shore power isn't hooked up it simply reads battery voltage. This project only cost about $16 in materials and to me, it's a very useful add-on.
8 REPLIES 8
IBcarguy
The switch was installed to simply kill the digital meter so it's not illuminated 24/7. I know it doesn't draw much but I thought it couldn't hurt.
corvettekent
I have three of these installed in my 5th wheel but I don't see any need for the switch. I also have the USB.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
IBcarguy
dewey02 wrote:
I was thinking of doing something similar. How did you wire it to measure inverter/charger rate when on shore power?
Actually this happened by accident. I pulled power from the hot side of a "battery disconnect" switch on the accessory switch panel on the other side of the entertainment center. The inverter is wired into the 12v system so whenever shore power is plugged in, it will read the voltage that is being pushed in to the batteries from the inverter/charger. With the shore power unplugged, it just reads whatever volts the batteries have. When I think about it, this would probably occur no matter where I picked up the power.
Artum_Snowbird
I have no need for another plug in 12 volt as my 800 watt inverter with USB plugs is installed. I bought a voltmeter with two decimal places from China for about $3.50 and it runs full time behind the breaker panel door.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
RoyB
I just purchased the same panel from AMAZON but I included the two USB charger modules...
The round modules rotate so you can have your panel horizontal or vertical...
These are made by BLUE SEA which are known for their quality and durability...
I also purchased one of these Equus Innova 3721 Battery and Charging System Monitor from AMAZON that plugs into a regular 12V SOCKET like in your truck. My truck does not 12VDC VOLTMETER which is great to have to watch battery and alternator performance.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
dewey02
IBcarguy
found it on amazon:
http://www.amazon.com/niceEshop-Marine-Cigarette-Lighter-Voltmeter/dp/B016OFBM3I/ref=sr_1_101?ie=UTF8&qid=1464549132&sr=8-101&keywords=cigarette+lighter+meter
gbopp
Nice. :C
Do you have a link for the receptacle/voltage meter?
