We have the Girard tankless water heater and have learned to live with it, without major incident. I have continuously disliked the waste of water trying to get hot water to the bathroom and other locations. Because on our model of the Seneca, the hot water heater is in the very back corner of the driver side and distance to the bathroom faucets and the shower and the kitchen faucets is a real reason that it takes so long to get hot water forward. It has been my thought, that replacing with a traditional RV water heater placed in the location of the Girard, would not change this distance.
Yesterday, I installed a 2.5 gallon electric hot water heater in the utility compartment, right under the wardrobe and behind the bathroom. Last night was the first test of showers and water usage. So far, so good. I've been pursuing this project for awhile and the concern was where to break in to the hot water line. I felt I had found the location in the outside faucet and up until a couple of days ago, that was what I was going to do. Change came when I was exploring where to get 110 volt power and decided to use the power outlet behind the wardrobe that was intended to be for the washer and dryer we chose not to install.
My original thought was to break in to the hot water line and add the electrically heated hot water in to the line coming from the Girard heater. Upon exploration of the electrical outlet, there was the hot and cold water faucets for the washer. Decided to use them. Drilled holes down to utility closet below and this has worked well. Shower now works much like a conventional shower with adjustment of both hot and cold water. As I installed this, I also installed pipe insulation on all hot water pipes I could reach.
As we "boondock" with limited water and limited electrical power about half the year. Water consumption is the biggest obstacle and the extra 2.5 gallons doesn't hurt. Limited electrical power is just using the generator or isolating the use of only one electrical appliance, including this new water heater, at a time.
Continuing to explore "the pursuit of happiness in this great Nation".
__________________
Smooth Sailing,
Ric and Jan
Southern Illinois
2016 Jayco Seneca 37FS "Low Key"
