โAug-18-2017 07:34 PM
โSep-21-2017 08:10 PM
RedRocket204 wrote:down home wrote:
Only way I see feasible now are the metal pole frames with the material stretched over them. I can't think of the name or brands but failing a hard side garage it would seem a better alternative, depending on price.
I have not done this... but you could easily make a frame out of 3/4-1" PVC pipe to where it is wider, by a few inches over each side and end. Just make sure the pipe touching the roof is only the pipe and not connector pieces. Should be smooth /rounded enough to not cause issues.
โSep-15-2017 09:23 PM
โSep-02-2017 06:18 PM
โAug-28-2017 03:46 PM
โAug-26-2017 03:22 PM
โAug-21-2017 05:01 PM
SoundGuy wrote:feel your pain but gotta cover up in California weather especially summer, covers only last about three years no matter we try,pain in ... to put on but if ya don't weather destroys them, need to research all manufacturers for a soft inside lining so movement from wind will not rub off finish and it will,good lucksmcrea wrote:
In the past we have tried all sorts of things to 'blunt' the corners and sharp edges to that the cover doesn't tear. We've used plastic balls to foam. All are a pin to install
Does anyone have any cheap and useful ideas on what to use?
3 covers over 10 yrs, no rips or deterioration at all. I use foam pipe wrap over the gutter extensions and scrap pieces of Reflectix over all sharp corners, both held in place with super sticky Duct tape. Even easier though is indoor storage, as I did last winter. :W
โAug-21-2017 04:48 PM
โAug-19-2017 09:07 PM
โAug-19-2017 06:35 AM
smcrea wrote:
It's time to install our cover after our last trip.
Thanks!
โAug-19-2017 04:49 AM
โAug-19-2017 04:40 AM
โAug-19-2017 04:39 AM
