bright enough?
btcruzer
I haven't read much about LED lighting lately but I just traded RVs and need to convert the lighting again. Previously, I'd used the bright ( or maybe "pure") white 48 5050 smds. I was pleased with them and didn't find them to be too bright. But my fixtures used a thick milkglass type lens so that might have cut down the light some. Now, my fixtures have the 1156 type bubs and typical RV style thin plastic lens. and I've found package deals for 48 3528 smd panels in warm white with 1156 base adapters. I'm needing at least 20 of these and want to keep it simple so I want the 1156 adapters. My question is " are people liking the warm white lighting and is the 3528 type bright enough?
The Good Times are Coming !
12 REPLIES 12
btcruzer
Too many numbers ! I have now installed panels with 48 3528 leds. Warm white. got them because of the 1156 adapters and ease of install. BUT I also have some with 9 5630 LEDs but g4 type bases.
how does the 5630s compare to the 5730s for current draw and light output?
By the way, I much prefer the 3528s to the old 1156 bulbs and I'm sure the current draw is much lower. I'd asked my wife to reorder more LEDS, she checked her recent purchases on EBAY and ordered. Wrong, Im getting more 5630s--- so I guess I'll find a way to convert them to 1156 bases.... I should have plenty of light -- so all is good.
eaglessoc
Gdetrailer wrote:
tenbear wrote:
In my experience I have found the 3528 LEDs are about half as bright as the 5050s, I also like the warm white. I have also found a big difference in venders on eBay. Whatever you decide on, buy 1 or 2 and try them before buying a whole bunch.
5050 LEDs although better than 3528 LEDs are not all that efficient.
5050 LEDs are .22W each and only give off about 10-15 lumens per chip.
on the other hand there are much more efficient LEDs, if you can find modules which use 5730 LEDs you will be much better off.
5730 LEDs are 1/2W each and can net you about 100-120 lumens per watt.
Basically 6 of the 5730s can give you more light than 48 of the 5050 LEDs..
Color, well that is up to you but LEDs really vary drastically in the color aspect.. 3000K to 4000K will get you pretty close to incadescent and 5000K-6500K is going to get you the harsher blue/white color..
Seems like you know what your talking about. I'm trying to replace the halogen bulbs in the puck style ceiling fixtures of my RV. I've tried various LEDs and had problems they seemed darker (less light) or harsh color. The fixtures use a G4 2 pin mount on the side. I need a pancake array. From you quote it appear I should buy:
1. Get an array of at least 6 LEDs 5730 type.
2. The 5730's should have a color temperature around 3000K to 4000K to get incandescent light color that is not too harsh.
Do you have a suggestion on purchasing source?
RVcircus
We have clear lenses in our fixtures and use 18 & 13 5050's depending on the location of the lights. The 18's were too bright in certain spots.
2000 KZ Sportsman 2505 (overhauled & upgraded 2014)
2016 Chevy Express 3500 15 passanger van
6 humans, 2 cats, and a dog
Visit our blog at www.ROWLESmade.com
Our trailer re-build thread
tenbear
Those are 3528 LEDs. You can tell the difference by the soldered contacts on the side of each LED. 5050 has 3 individual contacts on each side while the 3528 has only one wide contact on each side. Each 5050 has 3 individual LEDs in each package, thus the 3 contacts on each side.
2010 Subaru Impreza Sedan
Unit505
I thought these were the 5050smd. My exterior bulbs are. These I think are actually 3528's? Not sure. I went back to my purchase history and the add doesn't specify. Very bright. We use these lights ALLOT. No failures after 3 months. $15 for 20 bulbs. The scorched bulb socket that you see is what we found in every light fixture the day after we picked up the TT. The 194 halogens were way too hot for these fixtures. Fire hazard from the factory IMO.
http://www.ebay.com/itm/20-X-White-T10-Wedge-Trailer-RV-Landscaping-24-SMD-LED-Light-bulbs-W5W-921-1...
Moderator edit to re-size picture to forum limit of 640px maximum width.
KC5JLB Jeff
KC5KDB Kim
MrWizard
Moderator
Moderator
while this won't work for everybody..(those needing pancake squares)
i bought a 16ft roll of 5050 leds (hundreds) for $12 on Amazon
cut them into strips and wired them into my Fluorescent fixtures
last count i have 263 leds in 13 strips in 6 fixtures
and still have a little left over
I can't take credit for the idea..or order location
got both from another thread here on rvnet
I can explain it to you.
1997 F53 Bounder 36s
myredracer
If the pancake style of light fixtures, another option would be to replaced the existing lights with some that come with LEDS in them (that aren't a conversion). Available on ebay for around $15 and up.
Our 2014 TT came with pancake lights in them with OEM LEDs in them. I removed them all and replaced them with the light fixtures shown below from Kaper II. They have roughly the same footprint as the original lights and cover the existing screw holes. They're only about 1/2" thick.
I would get warm white lamps. The interior of RVs these days is typically warm colors (cabinets, flooring, upholstery, etc.) and warm color lamps will look and "feel" better for that reason alone. Cool color lamps will clash and seem unnatural and harsh. There's some that prefer cool over warm though and won't do without it.
I prefer the overhead lighting in our living/kitchen area to be on the brighter side for task lighting and cleaning. On 3 sides, we have puck lights under cabinets & slides and when watching TV, just have one set of the puck lights on. Our bedroom only had one pancake light and it was way too dim so I added a 2nd light (as in pic). I also added a puck light in the shower because that was dim too. Lighting levels are just a matter of personal preference. I also installed a couple of the removed LED pancake lights in our pass-through which works great when it's dark out.
If cost is an issue, LED replacements is the way to go and they are very inexpensive these days (on ebay at least).
btcruzer
so how many 5050smd are on those "pancake" things you mention? I haven't found anything with 5050s for anything like a dollar.
Unit505
5050smd pancake type led's are plenty bright. Don't understand how anyone could stand their rv to be any brighter? We've had the 5050smd pancakes since the day after we purchased our trailer, $1 each by the way off of ebay. We don't full time, but we do spend every weekend since August in the trailer and are very very happy with these bulbs.
KC5JLB Jeff
KC5KDB Kim
Gdetrailer
bamcote
We've converted some of our overhead lights to LED using the bright LED. We've found that the milky cover lens on the fixture does reduce the effectiveness of the light. We've switched some of the lenses out and it's perfect (unfortunately, for the price of a new lens cover).
DH, DW, Tildie, Bella and
Molly the Maine Coon
and Greta the shorkie pup
2008 Fleetwood Bounder 36Z
2007 Saturn Vue AWD with Ready Brake Brute
tenbear
