Changing shower to a bathtub
ice2fire
DW likes a bathtub instead of a shower. SO, how difficult/easy would it be to convert our shower to a bathtub ? Cost ?
Thanks for any suggestions/ideas.
2010 30' Heartland North Country, on a site in Tucson, Arizona.
27 REPLIES 27
stasha
Ice2Fire -- what did you decide?
If you put one in, can you post pix or give some details?
THx.
BTW, we have an Outlaw 37MD (motorhome with internal garage --Toy Hauler). Thinking of purchasing one of the 40+ inch tubs and just stowing it until needed (maybe pulley system to ceiling). Then pull it down and fill from the wash machine hoses when needed. Might put a drain in the floor to connect with wash machine drain -- or something like that.
ice2fire
No, I think it makes more sense to remove the U shaped piece of metal that goes all around the top. Is anyone reading any of this drivel ? Am I out on my own - again ?? ๐Ÿ™‚
ice2fire
Housted wrote:
The tub and surround are both 24 wide by 46 long.
The hard thing to find for some reason is the 24x46 surround??
I got the first tub/surround from the Northwood factory as part of the purchase.
The second tub/surround came from pplmotorhomes in Texas.
Good luck,
Housted
Thanks. So we're going to do it ! DW agrees, the RV repairman will do any plumbing, another guy, who has experience, will help build the walls etc ! We're going to use frp type walls from Home Depot for the ends and the back.
So first job is to dismantle the existing shower.
How does the door come off ? There is a straight piece of metal across the bottom, with three screws in it. I'm going to undo those first !
Wish me luck.
Housted
Good luck,
Housted
2019 Forrest River Forrester 3051S 2014 Honda CRV toad.
1000 W Solar, converted to 50 amp
400 Amps of LiFePO4,3000 Watt Inverter, Refer converted with JC refrigeration unit, Sofa replaced with 2 swivel chairs, over cab bed converted to TV mount and storage
ice2fire
Here is a link that should work....
first of three pics
Housted
Those look fantastic ! Thank you. Can I as you what size they are, the bath and surrounds manufacturer ? If I could duplicate those I think my DW would be in heaven ! (And so would I !)
Housted
ice2fire wrote:
Housted wrote:
I have converted two 5ers from 24" x 40" shower to 24" x 46" tub.
I moved a wall 6" to accommodate the tub. Everyone is right about the water
heater requirement. One of the conversions has a 12 gal and the other has a 16 gal.
DW is very happy with the results.
Photo -> https://photos.google.com/photo/AF1QipPo-Z_FlJaP5-jDE75uV2S68AHzQxDo4GWzJ6Q1
Housted
404 error on launch of link. I'd really like to look at them. Can you fix it please?
first of three pics
Housted
ice2fire
I see the flowing hot water units can be run on electricity or propane. Which is better ? Thanks.
ice2fire
CharlesinGA wrote:
http://www.rvpartscountry.com/RvBathtubs.html
Charles
Tried 'em. No 42" surrounds.
ice2fire
It seems there are two manufacturers making RV bathtubs: Lippert and www.icondirect.com. I really like the 42" long Icon, but they don't make a surround to fit it. Had a multiple e-mail session with them. Looks like I'll have to go with the Lippert 40", which is not so heavy (and thus probably not so good) as the Icon. Lippert have 40" surrounds. If anyone has a solution for the surround problem, I'd like to know. I maybe will strengthen the Lippert with fibreglass along the bottom.
I had a session with a fellow RV'er. He has one. He's going to help me and we'll use a professional to move the plumbing. Fortunately, the current surround sheets on the shower are not stuck to the wall, so should be easy to come off.
I told my DW. She is delighted !! I needed some inducements as she has a grand-daughter who wants her to stay home !! Got to fight fire with fire ! She's not that concerned about the hot water. She's a good "makedoer" ! Stay tuned.
ice2fire
Housted
CharlesinGA
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
MrWizard
Moderator
Moderator
Our second class A RV was an 82 Pace Arrow, with 24*46 tub
I'm 5'7" DW is 5'8"
And yes the tub was big enough to bathe
I don't know about the nay sayers, but I don't use only hot water to be scalded
Yes you will use more water than the avg RV Navy shower
If the OP can fit it in, I'm sure they will be happy
I can explain it to you.
1997 F53 Bounder 36s
Housted
Photo -> https://get.google.com/albumarchive/101217276011126966833/album/AF1QipPIU3XIfFV8xVdJRc_xK1P1gP9BZ0nJ3RzOhJBZ/AF1QipMB_BzfFUk8UHp0wv4pTAZFUrQuC4TVbuFrYdHu
Housted
stasha
ice2fire wrote:
More detective work needed. I have a RV man coming around soon to do a minor job soon. I'll ask him. Thanks.
Keep us posted on how this works out!
