โNov-23-2013 06:50 AM
โNov-27-2013 08:45 AM
pianotuna wrote:
Hi Christopher,
I doubt the propane would run out in two hours. Nor would I run low on 12 volt power to run the propane furnace. Power failure may be as simple as someone accidentally unplugging a cord by bumping it.
I am redundant for heating. Electric is the first line of defense, then the propane furnace. The RV can use both together if need be.
If necessary I can run the generator, then the V-10 motor for the class C. Of course, for those two options I must be there.
It is a deal breaker for me that cheap heat does not do fail over.christopherglenn wrote:
If you are worried about failover, then portable or baseboard with thermostats are about the only options. Don't forget AC power goes out, but propane runs out as well.
โNov-27-2013 08:06 AM
pianotuna wrote:
Hi jc,
Then they should provide it as an extra cost option instead of taking an Ostrich approach.jcthorne wrote:
Yes, an 'auto fail over' would only require the addition of a single relay to the installation. Its just something that very few would have need for so not included in the install kit.
โNov-27-2013 06:59 AM
โNov-27-2013 04:15 AM
โNov-26-2013 01:33 AM
โNov-25-2013 08:04 PM
โNov-25-2013 07:12 PM
โNov-25-2013 05:55 PM
โNov-25-2013 05:32 PM
harold1946 wrote:2-MTnesters wrote:
pianotuna thanks for the information. I would be getting the DH-37 unit as that is what the website matches to my furnace. My Montana does have the 4 seasons polar package with the sealed underbelly, R-38 batted insulation in the floors and ceiling, thicker sidewalls and insulated storage compartment doors. I really don't plan on staying in it in anything colder than the mid 2o's and won't be full timing for several more years and when that happens I'll be heading to warmer climates this time of year! Side note: I guess I can always use the fireplace heat to help out as well. Tim
John & Angela the baseboard heaters look great in your coach. Much smaller and more stream line than I had imagined.
The DH-37 is the plenum type and you will also need to specify which installation kit when ordering, there are three.
โNov-25-2013 05:19 PM
โNov-25-2013 12:44 PM
โNov-25-2013 12:08 PM
โNov-25-2013 10:52 AM
โNov-25-2013 07:40 AM
โNov-25-2013 07:27 AM
jcthorne wrote:Retired JSO wrote:
Your furnace will be close to 30-35,000 BTU.
I believe, Cheap Heat is about the same as the overpriced 120 volt electric heaters, so called produced by Amish Craftsman, to heat an entire home. The most heat they can supply is just over 5000 BTU. The same amount of heat a $39 Walmart space heater can supply. No where close to 30,000 BTU.
This is completely wrong. The 50A cheapheat system is roughly 5000 watts and runs 20A at 240VAC. Puts out approx. 16,000 BTU witch is roughly equal to a 26,000 BTU gas heater (60% efficient).
We installed the Cheapheat system about a year ago and could not be more pleased with it. Got rid of the 4 space heaters and the coach is warm and evenly heated throughout. Including the basement compartments. We have only used it in temps down to the low 20s but it was still cycling with significant off time so can go colder. This in a 38ft motorhome with 2 slides.
