DO NOT GO FOR THE ALLURE!
I put the allure in our class c about 2 years before we sold it. I went that route because of the sales pitch...."impervious to moisture, great for bathrooms, blah blah."
While that is true, it is super sensitive to temperature variations especially on its long axis. This left the MH with several 1/4" gaps in the floor in winter and a bow near the bed in summer. I installed exactly according to instructions. When I contacted the company about the gaps they emailed me super labor intensive instructions on cutting out old flooring and replacing with bigger tiles to fix the gap but did not address expansion.
The other negative was the sound. I did not do any underlayment and that made the coach much louder to walk through.
If I were to do it over I would either do a:
--single piece of vynil (no water issues).
--engineered hardwood. lighter weight, wears awesome, limited expansion and retains flex.
I don't think you would have trouble with the slides if you replaced the carpet under them. If the slide drags it will tear anything that is under it.
In the end its up to you and what you want to accomplish. For us it was getting rid of gross carpet and ease of cleaning.
If I were to do it again (I most likely will in our TT. I would shop around for a good deal on a 3/8 toungue and groove solid bamboo flooring. I would do a glue down installation and staple the groove as in a tradional residential installation.
Either route you go have fun with your project.
Happy Trails,
Jesse
2006 Cheverolet 2500
