Dometic analog thermostat to digital
firecapt1
Does anyone know how to hook up the new Dometic single zone digital thermostat when replacing the Dometic analog thermostat?
Evidently, the digital has a 3 wire connection and the analog has 6 wires. I haven't purchased the digital yet but the company assures me that it is a direct replacement.
I have emailed the company for installation instructions but I thought I'd also check here to see if anyone had already made the conversion and could give me some guidance.
Frank, Martha & Ryan
2007 Ford F-250 SD Crew Cab
2006 Cougar 289EFS
Happy Trails to you, until we meet again! :B
3 REPLIES 3
katysdad
To use the Dometic single zone thermostat you must also replace the control box mounted in the A/C. Without replacing the control it is not a direct replacement
Dodge Ram 3500 DRW Diesel
Sfla2
This is the 1 everybody is using get it on amazon
http://home.roadrunner.com/~morodat/hunter_install.html
98 Coachmen "C" Santara Model FL (Front Lounge) 30.4
Ford V 10 Super Duty (same as E 450)
2oldman
These posts have 'dometic thermostat' and 'zone' in them. Not too many so it's not overwhelming. Perhaps one will help..
