โMar-03-2020 07:13 PM
โMar-05-2020 05:29 AM
azrving wrote:agesilaus wrote:
Now that I think of it, I've used this method to crimp wire aircraft cable into loops. At the end of a cable. The tubing must be big enough to take two passes of the cable. Bend the cable around at the end into a loop end.
It's a heck of a lot cheaper to use a few inches of copper tubing and not those expensive aluminum splices sold to do this.
Wait a minute...not aircraft cable that is going up in the air? Right ??
โMar-04-2020 07:39 PM
โMar-04-2020 06:58 PM
โMar-04-2020 05:31 PM
โMar-04-2020 05:25 PM
โMar-04-2020 05:00 PM
โMar-04-2020 04:55 PM
โMar-04-2020 03:49 PM
Housted wrote:azrving wrote:
One exampleajriding wrote:
There is a crimping tool that looks like pliers, but has a crimp. This is easy.
I have soldered wires if I needed the best.
The pliers that put a dimple are not the way to do it. You need the type that uses dies and compresses it evenly. Never use solder on that type of connection. Hydraulic models are available on ebay etc for $35 or so
I have one of those in the link.....it has worked really well for years.
I have crimped wire up to 1/0 with great results.:B
Housted
โMar-04-2020 01:16 PM
โMar-04-2020 12:29 PM
โMar-04-2020 09:56 AM
โMar-04-2020 09:48 AM
โMar-04-2020 08:11 AM
โMar-04-2020 08:06 AM
