I just got a 2007 Tiffin Allegro as my first class A motorhome. So far, I have done the usual removal of the giant front TV box but I wanted to show another project.
Did Tiffin really make a medicine cabinet like this or was it someone's mod? It has three mirror panels, but only the two outer panels open??? I suppose fishing around behind the middle panel for long lost prescriptions could add some excitement, but I wanted to see everything.
I thought I would have to buy some of the really creative hinges like they make these days, but when I looked at it, it already had a hinge for the middle panel. It was just locked down on both sides.
I removed the hinge from one side of the middle panel and used a vice and hacksaw to make it a single hinge instead of a double. I filed the hinge to make it smooth after the sawing. I found I needed to file and sand the wood slightly to allow the middle door to close. There is not enough wood on the middle panel to use a traditional roller stay-closed device, so I will be using an adhesive magnetic one perhaps.
2007 Tiffin Allegro 28DA
