gate valve lube
bob213
saw this on another forum. Might help some
https://youtu.be/2GDErKY05-8
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
6 REPLIES 6
jjrbus
old guy wrote:
I have used the grease zerk fittings for years and years and all my TT's and never had a stuck gate
Zerks are the only way I will go, never had a problem with them!
ScottG
A weekly Mexican food meal and ours is kept working smooth.
old_guy
Lynnmor
When I replaced my cable operated valves, I ran small diameter tubing to the same place shown in the video. I used an old valve to test the silicone lubricant and it worked for a very short time, then it swelled the shaft seal making the valve tight and useless. Then I tried the same test on another valve using motor oil and that worked.
Ron3rd
I've seen similar posts here where a zerk fitting is installed and you pump the valve with grease. Your post looks like an easier option.
Equilizer Hitch
Honda EU2000
2oldman
Great idea. thanks.
