I have been working on upgrading the monitor panel for my motorhome.
I installed digital meters for 12 VDC and 120 VAC. 120 VAC monitor has a switch to check both legs of 50 amp service.
Couple years ago I installed a See-Level monitor for tanks. While it was a good install. It was mounted below OEM panel. Plus I still had to look at the original lights. I finally took the original panel out and cut the circuit board out. Then installed the See-Level monitor where the old lights used to be.
I also have Magnum AGS (Generator Auto Start). It is mounted behind the monitor board. Made a easy to remove panel. That allows access to the AGS when need to make adjustments.
I used black King Starboard to do this mod. It cuts with same tools used on wood.
Before.
After.
AGS.
Green light is AGS active. Can be seen when cover is on.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
