Multiple LED panels?
7lazy77
I would like to replace my old 1156 incadescents on the rear of my toy hauler (garage scare lights) with something brighter & more effecient. I am looking at the 48 SMD panel with the 2835 diodes (11 Watts / 580 lumen). I would be using the adapter it comes with for the connection, but the question that I have is could I put TWO of panels in there & be alright on the watts? If so, would I just splice the panel wires together to get power to both??
2011 Ram 3500 Cab Chassis
2011 Raptor 3812 Toy Hauler
70's Red Dale Truck Camper
6 REPLIES 6
WDP
I used 3 of the panels to upgrade an outside light, more lumens and still saved a bunch of watts. Just parallel till you get what you need.
WDP
4x4van
Take those lumen ratings for LEDs with a grain of salt. I converted my entire MH to LEDs about 2 years ago. Read about it here. Most 48-3528 panels will NOT put out more light than an 1156 incandescent. If I were you, I'd go with 48-5050 panels (5050's put out about 2X the light output of 3528 LEDs). I used 48-5050 panels to replace my 1141 bulbs; they work well, but are just slightly brighter (and 1156's are already brighter than 1141's). Also keep in mind that the color temp affects brightness also; with warm white (+/-3500K) putting out less lumens than bright (daylight) white (+/-5500K).
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
DarthMuffin
Yes, you can. I did exactly that on my exterior light. Two panels fit exactly in there. I had to splice the wiring together and shim up one end of the light housing with a layer of double sided foam tape (wasn't flat). The stock 1156 bulbs are about 400 lumen, so one panel is already brighter. One panel is plenty for interior use, but I wanted a nice bright exterior light (usually use the color changing LED strip under the awning so as not to be obnoxiously bright when not necessary).
rwbradley
I am not sure you will get brighter but will definitely get more efficient. I did 42SMD soft white round to replace my 921 bulbs and the lumens were 1/10 the incandescent. That was not really an issue for us as we do all our reading on backlit ebook readers and tablets anyway, and we preferred it not being as bright as an operating room. I would definitely get the flat LED's and get them in bright white if you want brighter. Some people have indicated that good brand name bulbs are brighter than some of the cheap ones off eBay. Even with 2 you may still be less bright than the original bulb though.
I did a full write up of my experience doing the LED upgrade with detailed brightness testing.
https://rwbradley12.wordpress.com/2015/08/24/led-light-upgrade/
Rob
rvtechwithrvrob.com
Ivylog
Led draw about 1/10th the power. You'll be OK
Upgraded with a 08 HR Navigator 45โ€™...
2oldman
A quick google check shows the 1156 draws 26w.
