Painting over wallpaper
GreetingsFrom
I was wondering if anyone has ever painted over the RV wallpaper?
I have a Thor Four Winds and contemplating painting the RV wallpaper. What type of paint would be best if I were to do this?
22 REPLIES 22
Oldme
Three year ago I used Kilz latex base primer (tinted to the top coat color),
then Bear latex paint.
No problems at all.
Forgot to add:
Light sanding to break the surface gloss of the wallpaper.
Cummins12V98
doxiemom11 wrote:
We like the Zinser Bullseye primer sealant better than Kilz. Used Kilz for years, then the store was out when we needed some so bought the Zinser - it was thicker and covered better. Didn't seem to stink as much either.
That is a good product also.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
doxiemom11
Bird_Freak
riven1950 wrote:
Have you actually slept in a house where you used this? I am trying to figure out why what you say is so different from my experience.
Yes, Painted all the ceilings in my S&B this past Spring in preparation for new carpet. Had some staining from blowing Hurricane winds / rain in past. Covered all stains 100%. We had windows / doors open during priming and slept in the house each night after painting. We did one room per day, primed, waited a few hours, painted over, slept like a baby ๐Ÿ™‚
Used on several mobile homes with the fabric walls and severe nicotine staining. Works great, even will work on wood paneling.
We also used the same in our S&B as well as the camper with no problem with smells.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
riven1950
Bird_Freak
riven1950 wrote:
http://www.kilz.com/primer/v/index.jsp?vgnextoid=6d0adb233122d310VgnVCM100000176310acRCRD
This is from the Kilz website. As I said before, put up with the oil based primer smell / fumes for 24 hours and you will get a better job in the end.
This is exactly what we did with our 5er and it turned out great.
Eddie
We love 56 T-Birds
Naio
The water based Kilz is good but I would not use it on wallpaper since the glue will loosen with water based primer.
Hmmm... when I have used it over wallpaper it has never loosened. I suppose it depends on the paper?
Looks like a good case for testing everything! Inside a closet ;).
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
Cummins12V98
Naio wrote:
Cummins12V98 wrote:
Naio wrote:
I really regretted using the oil based version of Killz indoors. And that was in an S&B house! I don't think it would be possible to sleep in the RV for at least 6 months, and more likely 12.
Not true the odor will dissipate quickly with proper ventilation and you can cover with your latex pain soon after the kilz is applied.
I would not sleep there the same day but surely not 6 months as you suggested. Let it dry it does not take long, a few hours. Then paint over with Latex. All with good ventilation. Yes I have done this.
I agree it's strong stuff but with proper ventilation it's a great product. The water based Kilz is good but I would not use it on wallpaper since the glue will loosen with water based primer.
Naio
Cummins12V98
Naio
I guess, from this thread, that the fumes do not bother some people as much. But I see no advantage to using the oil based, and a huge potential disadvantage. So why risk it?
Back in the day, 30-40 years ago, oil based primers stuck on better than water based ones. But, in my professional experience, that has not been true for a long time.
Cummins12V98
Yup! Beat me to it, best product out there. Hold your breath.
riven1950
coolmom42
I would rough up the surface with some fine grit sandpaper, then wash it with TSP. Use a WATER BASE PRIMER to keep odor down. Make sure the primer sticks well, as the post above says.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
